Log generated from Controller, need assistance deciphering
  • 1.  Log generated from Controller, need assistance deciphering
    Posted Aug 15, 2018 01:56 PM
    Community,
    Our Controller generated the following log yesterday and Im not sure what it means. Can you help? Thanks.
    08 14 2018 13:22:06 10.x.x.166 <LOC0:WARN> Aug 14 12:22:06 2018 wlan01.xxx.com <wlan01.x.x.com 10.x.x.166> httpd: [cgid:warn] [pid 4645:tid 344086] [client 172.16.10.65:57199] AH01264: script not found or unable to stat: /mswitch/apache/cgi-bin/wconfig.ha&arubalp=b561b4a3-11cf-4b3b-b7a6-11192df36c, referer: http://192.168.1.254/cgi-bin/wconfig.ha
  • 2.  RE: Log generated from Controller, need assistance deciphering
    Posted Aug 16, 2018 01:14 AM
    you can safely ignore this, it comes from apps on phones (usually) sending weird URLs to the controller webserver, if you search around for wconfig.ha in google you might find the app that caused it (but you can't very well tell people to uninstall it, so just ignore it).
