Logging level configuration vs severity for a syslog server
  • 1.  Logging level configuration vs severity for a syslog server
    Posted Aug 28, 2014 05:46 PM
    Hi, my controller is set with this  configuration:
    # show logging level verbose
    LOGGING LEVELS
    Facility Level Sub Category Process
    network warnings N/A N/A
    security informational N/A N/A
    security debugging N/A authmgr
    security informational aaa N/A
    security debugging dot1x N/A
    security warnings ids N/A
    security warnings ids-ap N/A
    system warnings N/A N/A
    user informational N/A N/A
    user debugging dot1x N/A
    wireless warnings N/A N/A
    # show logging server
    Remote Server: 172.17.xxx.xx
    FACILITY MAPPING TABLE
    local-facility severity remote-facility
    user warnings local1
    security warnings local1
    Why my syslog server is receiving logs with the tag <NOTI> if the severity is set for WARN?
  • 2.  RE: Logging level configuration vs severity for a syslog server
    Posted Aug 29, 2014 06:59 AM
    try this:
    logging level warnings security subcat aaa
    logging <Server IP> type user severity warnings facility local0
  • 3.  RE: Logging level configuration vs severity for a syslog server
    Posted Aug 29, 2014 08:17 AM
    But it's not possible to have internal security log with INFORMATIONAL level and send to syslog server only WARNINGS and above? Is it?
  • 4.  RE: Logging level configuration vs severity for a syslog server
    Posted Aug 29, 2014 08:29 AM
    Yes you can have informational same way as warning level
