Login failed for 7030 controller
  • 1.  Login failed for 7030 controller
    Posted Jul 14, 2020 11:13 AM
    ***Problem has been solved. Another user was able to log in and we reset passwords. Apparently, I was using the wrong ones.***
    I was logged in to the controller last week and now it just tells me "Log In failed."
    I've tried my account and the admin account and neither work.
    I've rebooted the device using the front panel, but still can't log in over the network.
    Wireless networks all appear to be working just fine.
    I haven't had a chance to ask any of my colleagues if their logins work, but I figured I'd reach out to the community to see if anyone had any insights.
    Thanks.
  • 2.  RE: Login failed for 7030 controller
    MVP GURU
    Posted Jul 14, 2020 12:14 PM
    If you can gain console access, you cna reset your admin password by using password as username and forgetme! as the password. From there change the password via cli.
  • 3.  RE: Login failed for 7030 controller
    Posted Jul 14, 2020 12:43 PM
    Another of our admins was able to log in and reset my password.
    Thanks for the suggestions!
