Login Status:REJECT on Clearpass (Cannot select appropriate authentication method)
This thread has been viewed 54 times
  • 1.  Login Status:REJECT on Clearpass (Cannot select appropriate authentication method)
    Posted Feb 08, 2018 02:12 AM
    Hi all,
    I'm deploying an SSID for guest with Captive portal in clearpass following this guideline https://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/How-to-integrate-Aruba-Controller-with-CPPM-to-perform-Captive/ta-p/192291 . When i tesed it, i saw alot of log REJECT with Alert:
    Error Code:
    201
    Error Category:
    Authentication failure
    Error Message:
    User not found
     Alerts for this Request
    RADIUS[Guest User Repository] - localhost: User not found.
    Any one can help me resolve this issue ?
    Many thanks for help.
  • 2.  RE: Login Status:REJECT on Clearpass (Cannot select appropriate authentication method)
    MVP
    Posted Feb 12, 2018 03:57 PM
    The authentication source you're using is the Guest User Repository and the error indicates that the user account does not exist. I see the username being sent is the MAC address of the device, are you doing MAC authentication here? You should include the Guest Device Repository instead of Guest User Repository.
    Is the MAC address registered in the Guest Device Repository?
  • 3.  RE: Login Status:REJECT on Clearpass (Cannot select appropriate authentication method)
    Posted Feb 13, 2018 09:58 AM
    Hi
