Hello all
I'm using an hp1810 switch and couldn't find any newer firmware than the following:
HP 1810-24G, PL.2.04
Unfortunately the SSL Logjam vulnerability is not fixed within this level. I know how to tweak firefox'es security settings to allow a connection to the webinterface anyway (about:config -> set security.ssl3.dhe_rsa_aes_128_sha and security.ssl3.dhe_rsa_aes_128_sha to false).
Since there seems no way to change the behaviour of the intergrated webserver over the webgui, I was wondering if there is any other way to generate new Diffie-Hellman groups. Or of course a fixed firmware would be even better! I think we could expect that from an enterprise level product ...
Cheers
#SSL
