Looking for suggestions - RAP + 3G/4G modem
  • 1.  Looking for suggestions - RAP + 3G/4G modem
    Posted Apr 25, 2014 12:01 PM
    Hello Airheads-
    I am looking into a project that would allow our campus to create a hotspot beyond the reaches of the wireless network(outside in the middle of nowhere).  I came up with a solution that uses a RAP, a cell modem, and batteries.  Here is what I plan to use:
    1.  Battery power
    2.  RAP5
    3.  USB 3G/4G modem with (important) External antennas
    I have seen other posts with similar setups, but I am looking for other people's ideas/suggesstions on my requirements.  Thanks!
    Matt
  • 2.  RE: Looking for suggestions - RAP + 3G/4G modem
    Posted Apr 25, 2014 01:06 PM
    The Verizon UML290 3g/4g modem probably had the first and best support for RAPs.   I am only mentioning that one because I have the best and longest experience with that one and it works.  I am sure there are a number of others who would chime in with their favorites.
  • 3.  RE: Looking for suggestions - RAP + 3G/4G modem
    Posted Apr 26, 2014 04:39 PM
    My fav is ZTE MF821 - it is cheap and more important - easy available in my country.
  • 4.  RE: Looking for suggestions - RAP + 3G/4G modem
    Posted Jun 16, 2014 01:38 PM
    Hi, Do you have the config for ZTE 821 3G&4G modem?
