Network Management
Loop Protection issue/question
  • 1.  Loop Protection issue/question
    Posted Jan 19, 2012 10:30 AM
    We would like to implement Loop Protection on our HP switches on our LAN.
    We started by testing with a 2510G-24 with a basic configuration:
    ; J9279A Configuration Editor; Created on release #Y.11.35
    hostname "ProCurve Switch 2510G-24"
    ip default-gateway 172.18.46.11
    snmp-server community "public" Unrestricted
    snmp-server host 172.18.46.33 "public" All
    vlan 1
       name "DEFAULT_VLAN"
       untagged 1-24
       ip address 172.18.46.209 255.255.255.0
       exit
    loop-protect 1-24
    loop-protect trap loop-detected
    loop-protect disable-timer 15
    We connected a dumb switch to one of the 2510 ports, then caused a loop on the dumb switch.  The 2510 immediately sensed the loop and disabled the port.  It would re-enable the port after 15 seconds and immediately disable the port again when it detected the loop was still there.  When we took out the loop, the port was re-enabled and stayed that way.  It worked exactly as expected.
    We then connected another of the 2510 ports to our production LAN via a simple daisy-chain.  None of the other switches in the LAN have Loop Protect turned on.  With that connection in place, the Loop Protect no longer worked.  The test 2510 logs a "high broadcast" rate for the port with the looped-dumb-switch, but no longer detects the loop.  If we disconnect the cable to the production LAN, the Loop Protect works properly again.
    What could cause the Loop Protect to fail when we are connected to our Production LAN?  Is there some protocol that could be overriding/suppressing Loop Protect on our test 2510 switch?
    Thanks for any insight that you can provide on this issue.
    Bryan Hunt
    #loopprotection
