Wired Intelligent Edge
Loops in the switch
  • 1.  Loops in the switch
    Posted Apr 27, 2019 09:21 PM
    Will i be able to disable the ports if there are loops in the switches ?
    (example: port 1 is connected to port 2 which is not neccessary as per the config )
    My topology has JL262A switches
  • 2.  RE: Loops in the switch
    Posted Apr 28, 2019 03:27 AM
    What type of switch are you using?
  • 3.  RE: Loops in the switch
    Posted Jul 07, 2019 10:06 AM
    my network is having JL262A procurve 48 port switches
  • 4.  RE: Loops in the switch
    Posted Apr 30, 2019 05:16 AM
    Next to spanning tree on the edge interfaces you can use loop-protect, you can configure loop protect to disable ports for a period of time. i woud always advise to use spanning tree combined with loop-protect for edge loop detection.
    config example:
    loop-protect 1-48
    loop-protect disable-timer 60 (or any other value in seconds you wish)
  • 5.  RE: Loops in the switch
    Posted May 29, 2019 12:11 AM
    Loop protect is a good starting point but I would also look at BPDU protection. Loop Protect is only working on untagged ports, which are in the same VLAN and on the same switch.
    I have written a post about loop protection and BPDU protection here:
    https://www.flomain.de/2018/01/protect-from-spanning-tree-loops-access-area/
    Just have a look and decides which one fits better in your environment.
    BR
    Florian
  • 6.  RE: Loops in the switch
    Posted Jul 07, 2019 10:07 AM
    would loop protect disable the ports permanently
  • 7.  RE: Loops in the switch
    Posted Jul 24, 2019 10:04 AM
    if you use the loop-protect disable-timer XX where XX is the number of seconds the ports would be disabled for.  with out this command i believe the ports would be disabled until the switch reboots next.
