Lost Controller Management
  • 1.  Lost Controller Management
    Posted Aug 05, 2014 11:29 PM
    Hi. I have an Aruba Controller 3200XM with 6.3.1.9 version. After adding the first PEFNG license I lost SSH and Web management. The only way to manage the Controller is thru console cable. Does anyone have any advice to fix it
    #ALE
  • 2.  RE: Lost Controller Management
    Posted Aug 05, 2014 11:31 PM
    Make sure the port that is connected to your network is trusted.
    For example:
    show interface gigabitethernet 0/1
    Look for This port is TRUSTED near the bottom
  • 3.  RE: Lost Controller Management
    Posted Aug 05, 2014 11:47 PM
    If it is not marked as trusted; run the following for the appropriate port:
    config t
    interface gigabitethernet 0/1  (or appropriate port or port-channel for your connection)
    trusted
    wr mem
  • 4.  RE: Lost Controller Management
    Posted Aug 06, 2014 06:37 PM
    Thanks Clembo. After marking the port as trusted the management of the controller got back
