There was a pre-*** tarball and I thought that would work, but after following the directions you gave, I came up with the following error:
Caused by: java.lang.RuntimeException: SnapshotImage file[/var/airwave/data/0b34cef7-b0ab-4954-9a54-9767cc456e79/thumb.jpg] does not exist
That 0b34... directory doesn't exist. It's now in the visualrf-save dir I created. I tried copying it back, but it doesn't work. How do I tell visualrf not to use the old 0b34... stuff and use what's in /var/airwave/data/... directory?
--myron
