There are 4 MSM430 connected via Phihong POE36U-1AT-R to HP 4204VL, managed by MSM710. There is a 5th one in a different room.
SInce the weekend none of the 4 is recognized by the 710. The 5th is working. If I change the 5th with one of the 4, it is working there, too. If I bring any of them to the 5th's place, it is not working there neither.
Experience:
when the device is connected, after a short time the power led turn on and after a short flash start to ligth. Then the 2nd wifi led is flashing, the two middle (network and wifi 1) are flashing together, maybe once in a second.
DHCP has assigned IP to its MAC. It gets IP immediately and pingable. 710 didn't find it neither during rescan.
I tried to reset in several ways: I tried to release the reset button after one long flash, 1 long and n short flashes where n is 1, 2, 3, 4, 5. Didn't change anything. Once I released the button, it became pingable in 1-2 seconds and went back to the recently described lighting mode.
I am not able to reach the device via https://ip
Q1: Do you have any idea what could happen, why we "lost" those devices?
Q2: why the reset doesn't work? or should I remove from the current network for this?
Thanks in advance for any idea.
(ps: SSID doesn't show up in that room)
#msm430#problem
