Wired Intelligent Edge
Low CIR and High Drops TX during backups
  • 1.  Low CIR and High Drops TX during backups
    Posted Apr 30, 2019 04:29 PM
    Good afternoon to all, I hope your day is going well. I have an interesting issues that has plauged me for about three weeks now. I have a 250Mbps AT&T switched ethernet (ASE) Circuit that was installed about a month ago in a data center about 100 miles away from me. Ever since it was installed I have been having a lot of trouble with it. When I run IPerf against it, the best throughput I am able to achieve is 65-90 Mbps. I have another 250Mbps ASE that works perfectly fine. Both the working circuit and the ailed circuit are configured essentially the same. To add to this, while running back ups against the slower circuit, I am seeing a significant amount of Drops TX on the port. The only noticeable large differances are one uses a fiber port as the uplink and the other uses an ethernet port as an uplink. All vlan 1 traffic is for local addressing, and it is all forwarded back to a central location via a default route. The speed tests I have completed both orginionated from the same machine at the same location.  I have included snippits of the configs and show commands below:
    Bad Circuit config:
    ip route 0.0.0.0 0.0.0.0 X.X.X.X
    ip routing
    interface 24
    rate-limit all out kbps 250000
    exit
    vlan 1
    name "DEFAULT_VLAN"
    untagged 1-23,A1-A4
    tagged 24
    ip address X.X.X.X 255.255.255.0
    exit
    vlan 339
    name "VLAN339"
    tagged 24
    exit
    spanning-tree
    spanning-tree force-version rstp-operation
    Bad show int (uplink port only)
    DR-1# show int e 24
    Status and Counters - Port Counters for port 24
    Name :
    MAC Address : ecebb8-10b768
    Link Status : Up
    Totals (Since boot or last clear) :
    Bytes Rx : 1,934,220,284 Bytes Tx : 1,020,228,678
    Unicast Rx : 38,933,610 Unicast Tx : 24,699,894
    Bcast/Mcast Rx : 1,396,441 Bcast/Mcast Tx : 361
    Errors (Since boot or last clear) :
    FCS Rx : 0 Drops Tx : 3,228
    Alignment Rx : 0 Collisions Tx : 0
    Runts Rx : 0 Late Colln : 0
    Giants Rx : 0 Excessive Colln : 0
    Total Rx Errors : 0 Deferred Tx : 0
    Others (Since boot or last clear) :
    Discard Rx : 0 Out Queue Len : 0
    Unknown Protos : 0
    Rates (5 minute weighted average) :
    Total Rx (bps) : 58,154,168 Total Tx (bps) : 6,656,032
    Unicast Rx (Pkts/sec) : 5,375 Unicast Tx (Pkts/sec) : 3,110
    B/Mcast Rx (Pkts/sec) : 262 B/Mcast Tx (Pkts/sec) : 0
    Utilization Rx : 05.81 % Utilization Tx : 00.66 %
    Bad Show int bri (uplink port only)
    24 100/1000T | No Yes Up 1000FDx MDI off 0
    Below this line is the good configs
    Good Config:
    ip routing
    interface A1
    exit
    vlan 1
    name "DEFAULT_VLAN"
    no untagged 23
    untagged 1-22
    tagged 24,A1-A4
    vlan 339
    name "VLAN339"
    tagged A1
    exit
    spanning-tree
    Good Show int (uplink port only)
    Status and Counters - Port Counters for port A1
    Name :
    MAC Address : 94f128-3ec866
    Link Status : Up
    Bytes Rx : 1,586,525,170 Bytes Tx : 1,955,749,768
    Unicast Rx : 10,759,389 Unicast Tx : 8,007,591
    Bcast/Mcast Rx : 6,114,765 Bcast/Mcast Tx : 677,618
    FCS Rx : 0 Drops Tx : 282
    Unknown Protos : 0
    Total Rx (bps) : 573,016 Total Tx (bps) : 160,128
    Unicast Rx (Pkts/sec) : 67 Unicast Tx (Pkts/sec) : 43
    B/Mcast Rx (Pkts/sec) : 222 B/Mcast Tx (Pkts/sec) : 21
    Utilization Rx : 00.05 % Utilization Tx : 00.01 %
    Good show int bri (uplink port only)
    A1 1000SX | No Yes Up 1000FDx NA off 0
  • 2.  RE: Low CIR and High Drops TX during backups
    MVP GURU
    Posted Apr 30, 2019 05:05 PM
    Switch models and software versions?
  • 3.  RE: Low CIR and High Drops TX during backups
    Posted Apr 30, 2019 07:08 PM
    The switch models are both Aruba 3810M (Jl073X).
    The bad switch is on firmware version KB.16.06.0009
    The good switch is on firmware version KB.16.05.0007
  • 4.  RE: Low CIR and High Drops TX during backups
    Posted May 01, 2019 02:06 AM
    The number of drops at the switch is really low. Could it be possible that there is an issue with the circuit?
  • 5.  RE: Low CIR and High Drops TX during backups
    Posted May 01, 2019 08:12 AM
    Thats my thoughts too, but I have fought with AT&T for days to get them to check it. They said every hop along the way is showing the correct throughput, including to their device at the remote location. They told me their device was showing 220 Mb throughput at times. The only thing I can think of that I  have not tried is moving the uplink port from port 24 to another port, and asking the datacenter to check the cable in between my equipment and AT&T, but I have not done that yet because I am still getting Solid traffic to my switch, its just slower than its supposed to be and occasionally has TX drops. does anyone think a bad layer one could be the cause?
  • 6.  RE: Low CIR and High Drops TX during backups
    Posted May 01, 2019 09:19 AM
    Ran a single backup last night. It was my exchange server. The back up finished, but it took about 8 hours, and this was the results of the show int this morning
    Port: 24
    Total Bytes: 1,507,117,687
    Total Frames: 887,010,432
    Errors RX: 0
    Drops TX: 17,076
    Flow Control: off
    Bcast Limit: 0
  • 7.  RE: Low CIR and High Drops TX during backups
    Posted May 01, 2019 09:35 AM
    There are just a few TX drops. I don't suspect issues because of this drops.
    Is it possible to connect directly to the AT&T router and do a iperf from there?
