  • 1.  Low Memory
    Posted Jul 20, 2017 07:17 AM
    What is the minimum memory required on the controller to operate without any issues ?
    i have the log file and i don't know if that free memory is sufficient or not .. and if it will cause any issue ?
    Attachment(s)
    txt
    DIFC-Aruba.txt   1.50 MB 1 version
  • 2.  RE: Low Memory
    Posted Jul 24, 2017 05:16 AM
    Please refer Advisory
    "Aruba 600 Series Branch Office Controller Out-of-Memory Support Advisory - SA-20160621 - Tuesday, June 21, 2016"
    http://support.arubanetworks.com/Announcements/tabid/139/Default.aspx
    Which talks about the Out of memory issue on Aruba 600 series controller.
    Note: You should login to support site to view the Advisory.
  • 3.  RE: Low Memory
    Posted Jul 25, 2017 11:28 AM
    Thank you so much
  • 4.  RE: Low Memory
    Posted Jul 25, 2017 04:18 PM
    My pleasure!
