lower data rates
  • 1.  lower data rates
    Posted Jun 24, 2016 09:50 PM
    Is it true that  we should not  disable  lower data rates  to save airtime like 1 ,6 Mbps.
    If its true what reason ?
  • 2.  RE: lower data rates
    Posted Jun 24, 2016 09:54 PM
    Take a look at the VHD VRD which discusses data rates in great detail.
    There is also an RF optimization wizard on ASE.
  • 3.  RE: lower data rates
    Posted Jun 25, 2016 08:42 AM
    @kpaly wrote:
    Can you please show where that is written?
  • 4.  RE: lower data rates
    Posted Jun 26, 2016 04:35 PM
    I think  its in one of the videos( cwna) jeromy I belive
  • 5.  RE: lower data rates
    Posted Jun 26, 2016 04:53 PM
    You might want to ask Jeromy if that is where you see it..
  • 6.  RE: lower data rates
    Posted Jun 28, 2016 03:26 AM
    Maybe Jeromy is pointing something else . My understanding might be wrong :)
    Here is the statment
    802.11b and 802.11a set default data rates to make sure that all stations would understand all modulation in the (new in those days ) protocols
  • 7.  RE: lower data rates
    Posted Jun 28, 2016 05:46 PM
    There is no single answer, it is dependant on many variables. Client type and enviroment details are probably the biggest determining factors.
    Here's some thoughtful writing on the topic- http://www.sniffwifi.com/2016/01/why-you-shouldnt-disable-low-wi-fi.html (Take with grain of salt before you apply generic advice to your specific environment.)
