Just tried to change the port speed to 100Mbps on an M3 but I'm getting a reject message - "speed configuration not supported" an idea why?
There are only 1GB and 10GB ports, no 10/100/1000 ports.
Is there any way I can restrict the traffic flow through the port to 100Mbps?
Not sure what you mean, however this is production controller so that would not be an option.
By using a dumb switch in the middle, you have the 100M link plug into the dumb switch then the dumb switch plugs into the controller at 1000M. It acts as a passive step down / up device.
Unfortunately there is no other way.
I see what you mean now, the customer would want a cleaner solution than that even though it would do the job. Thanks for the help anyway.
