mab configuration with cisco swicth for non user device like printer an scanner
  • 1.  mab configuration with cisco swicth for non user device like printer an scanner
    Posted Sep 27, 2014 05:36 AM
    hi,
    am tryin to do mab authentication for 200 device in our company using clearpass with cisco switch,
    i have already confiugred cppm as below:
    wired service its working,
    mac auth service its working if i add the mac address of printer on white list,
    what i want is, i dont want to add all mac addresses on white list,
    i have enabled ip device sensor and lldp and cdp configuration on cisco,
    what should i do now  on clearpss
    here the attachment for cisco device sendor i found it on aruba site
    thank you
  • 2.  RE: mab configuration with cisco swicth for non user device like printer an scanner
    Posted Sep 27, 2014 09:40 AM
    it says it:
    1 . CPPM should be configured with interim packet update enabled
    you do that under server configuration on clearpass, then service configuration (don't know the exact tab name) and then radius server and all the way below.
    looking at that i assume it will just extend on your endpoint repository with info to use on your service.
