MAB not working mitel - how can i authenticate Phone on the network
  • 1.  MAB not working mitel - how can i authenticate Phone on the network
    Posted Nov 01, 2018 09:24 PM
    The phone is registering with a username on clearpass,
    I want to enable all device to be allowed not matter what for testing. Monitor mode only doesnt implement enforcement, and I can't use the auth vlan on the switch config as there is phones tagged on voice on ports. (Or would this still work)
    I understand for MAB to work the username needs to the MAC, this phone isn't - is this abnormal?
  • 2.  RE: MAB not working mitel - how can i authenticate Phone on the network
    Posted Nov 01, 2018 09:40 PM
    Failing phonesFailing phonesService configService config
  • 3.  RE: MAB not working mitel - how can i authenticate Phone on the network
    Posted Nov 01, 2018 09:54 PM
    You should really use the MAC Auth service template. The service you have is not specific enough.
  • 4.  RE: MAB not working mitel - how can i authenticate Phone on the network
    Posted Nov 01, 2018 09:59 PM
    the logs show that the username is appearing as JBORLAND not the MAC address
    So i understand why its not working, but how do i get it working without re-configuring all the pone before i enable it.
  • 5.  RE: MAB not working mitel - how can i authenticate Phone on the network
    Posted Nov 01, 2018 10:01 PM
    It's likely a switch misconfiguration.
  • 6.  RE: MAB not working mitel - how can i authenticate Phone on the network
    Posted Nov 02, 2018 05:45 AM
    I agree with the service point, I have this service at the bottom and was meant to be a catch all for everything on the wired, hence this configuration.
    I thought this was the phone itself,
    somebody has configured the phones to do EAP with a username and password - is there a way to allow all devices using EAP even if they fail authentication.
    I am unable to use the unatuth-vid as the VLAN are not consistant across the sites and require configure 250 ports by hand.
