MAC address based auth is ignored
  • 1.  MAC address based auth is ignored
    Posted Oct 12, 2020 02:42 PM
    I do have to setup a WLAN where only registered MAC-addresses should be able to login.
    1.
    For testing purposes I created on a 7005 w/ 8.6.0.6 a new WLAN (called "MAC") with security:personal WPA2 and Mac Authentication enabled.
    2.
    Then I went to Authentication -> L2-Authentication and created a new authentication Profile (delimeter:colon, case:lower, max auth. failures:0)
    3
    Then I went to Auth server -> internal -> internal and added a new user with username:password = xx:xx:xx...:xx:xx:xx... with role "default-via-role" and clicked "enabled".
    4
    Now I went to AAA profiles -> AAA  and found a new profile called "Mac_aaa_prof" The only thing here I touched was to click on "MAC Authentication" and to choose as MAC Authentication Profile the profile I created in Step 2.
    This is the way I do understand the advice here
    But unfortunately every client with knowledge of the WPA2-PSK can login to this WLAN.
    My guess is that I am missing something in step 4.
    Are there any ideas...?
    Thanks!
  • 2.  RE: MAC address based auth is ignored
    Posted Oct 12, 2020 02:51 PM
    That mac auth profile needs to be configure in the AAA profile that you are using to allow WPA2 users on with.  If you get on the commandline and type "show user-table" the profile in the profile column is the AAA profile that you need to add the mac authentication profile to.
  • 3.  RE: MAC address based auth is ignored
    Posted Oct 13, 2020 05:16 AM
    I amtesting with a new device which was never before used in that WLAN.
    It can enter the given WLAN "MAC" as soon as I type in the WPA2 passphrase gets an IP and everything is working - but it should not be allowed to.
    show user-table gives me for this device:
    Profile=MAC_aaa_prof
    _________________________________
    show aaa profile MAC_aaa_prof:
    AAA Profile "MAC_aaa_prof"
    Parameter                                               Value
    Initial role                                            default-via-role
    MAC Authentication Profile                              MAC
    MAC Authentication Default Role                         guest
    MAC Authentication Server Group                         internal
    802.1X Authentication Profile                           MAC_dot1_aut
    802.1X Authentication Default Role                      guest
    802.1X Authentication Server Group                      N/A
    Download Role from CPPM                                 Disabled
    Set username from dhcp option 12                        Disabled
    L2 Authentication Fail Through                          Disabled
    Multiple Server Accounting                              Disabled
    User idle timeout                                       N/A
    Max IPv4 for wireless user                              2
    RADIUS Accounting Server Group                          N/A
    RADIUS Roaming Accounting                               Disabled
    RADIUS Interim Accounting                               Disabled
    RADIUS Acct-Session-Id In Access-Request                Disabled
    XML API server                                          N/A
    RFC 3576 server                                         N/A
    User derivation rules                                   N/A
    Wired to Wireless Roaming                               Enabled
    Reauthenticate wired user on VLAN change                Disabled
    Device Type Classification                              Enabled
    Enforce DHCP                                            Disabled
    PAN Firewall Integration                                Disabled
    Open SSID radius accounting                             Disabled
    Apply ageout mechanism on bridge mode wireless clients  Disabled
    ___________________________________
    show profile-list aaa authentication mac:
    MAC Authentication Profile List
    Name             References  Profile Status
    default          0
    MAC              1
    What is missing...?
  • 4.  RE: MAC address based auth is ignored
    Posted Oct 14, 2020 03:51 AM
    No one any idea?
    In this posting is written by @cjoseph
    "For a client to connect successfully on an 802.1x network with encryption it needs a username or password. That is not optional. What is optional is passing mac authentication."
    So how do I make MAC authentication mandatory instead of optional?
  • 5.  RE: MAC address based auth is ignored
    Posted Oct 14, 2020 03:57 AM
    The initial role in your AAA profile is default-via-role.  That means devices that enter without passing authentication will have that role.  You need to change it to something restrictive, so that if a device passes PSK, but fails authentication, the initial role will restrict them.  Your mac authentication default role should be the role that your users obtain after passing mac authentication and should be permissive.
  • 6.  RE: MAC address based auth is ignored
    Posted Oct 14, 2020 05:28 AM
    @cjoseph Thank you, I can try this in 20h when I am hands on to the controller.
    Is there any good documentation about these "roles" and which is best suited for what purpose ? I must admit that I have never been involved...
  • 7.  RE: MAC address based auth is ignored
    Posted Oct 26, 2020 12:04 PM
    I still need help with this.
    When I assign a role like "guest" still everybody can login into the WLAN and MAC addresses are not filtered.
    What kind of role should I apply to this specific WLAN?
