show interfaces 3
Status and Counters - Port Counters for port 3
MAC Address : 08f
Link Status : Up
Port Enabled : Yes
Totals (Since boot or last clear) :
Bytes Rx : 230,544,170 Bytes Tx : 1,694,811,906
Unicast Rx : 1,027,525 Unicast Tx : 1,845,838
Bcast/Mcast Rx : 4,674 Bcast/Mcast Tx : 7,475,156
Errors (Since boot or last clear) :
FCS Rx : 0 Drops Tx : 1,861,328
Alignment Rx : 0 Collisions Tx : 0
Runts Rx : 0 Late Colln Tx : 0
Giants Rx : 0 Excessive Colln : 0
Total Rx Errors : 0 Deferred Tx : 0
Others (Since boot or last clear) :
Discard Rx : 0 Out Queue Len : 0
Unknown Protos : 0
Rates (5 minute weighted average) :
Total Rx (bps) : 0 Total Tx (bps) : 0
Unicast Rx (Pkts/sec) : 0 Unicast Tx (Pkts/sec) : 0
B/Mcast Rx (Pkts/sec) : 0 B/Mcast Tx (Pkts/sec) : 0
Utilization Rx : 0 % Utilization Tx : 0 %
show port-access clients
Port Access Client Status
Port Client Name MAC Address IP Address User Role Type VLAN
5 host/ n/a 8021X 12
7 001a n/a MAC 10
12 host n/a 8021X 12
13 00d n/a MAC 12
18 80e n/a MAC 12
19 001a n/a MAC 10
23 host/ n/a 8021X 12
port 3 is missing
show port-access mac-based clients
Port Access MAC-Based Client Status
Port MAC Address IP Address Mode Client Status
7 001a n/a User authenticated
13 00d n/a User authenticated
18 80e n/a User authenticated
19 0018 n/a User authenticated
25 001 n/a User authenticated
show port-access 3 clients
# show running-config interface 3
Running configuration:
interface 3
untagged vlan 999
aaa port-access authenticator
aaa port-access authenticator client-limit 1
aaa port-access mac-based
aaa port-access mac-based mac-pin
spanning-tree admin-edge-port
spanning-tree point-to-point-mac false
exit
Aruba-2540-48G-PoEP-4SFPP-BZ31# show logging -r | incl "port 3"
I 07/26/24 13:28:08 00076 ports: port 36 is now on-line
I 07/26/24 13:28:08 00435 ports: port 36 is Blocked by STP
I 07/26/24 13:28:08 00435 ports: port 36 is Blocked by AAA
I 07/26/24 13:27:47 00077 ports: port 36 is now off-line
I 07/26/24 13:27:47 00435 ports: port 36 is Blocked by AAA
I 07/26/24 13:27:25 00077 ports: port 36 is now off-line
I 07/26/24 13:09:23 00435 ports: port 3 is Blocked by AAA
I 07/26/24 13:09:22 00077 ports: port 3 is now off-line
I 07/26/24 13:09:21 00435 ports: port 3 is Blocked by AAA
I 07/26/24 13:09:19 00077 ports: port 3 is now off-line
I 07/26/24 11:49:20 00076 ports: port 3 is now on-line
I 07/26/24 11:49:20 00435 ports: port 3 is Blocked by STP
I 07/26/24 11:49:00 00435 ports: port 3 is Blocked by AAA
I 07/26/24 11:48:59 00077 ports: port 3 is now off-line
I 07/26/24 11:47:00 00076 ports: port 3 is now on-line
I 07/26/24 11:47:00 00435 ports: port 3 is Blocked by STP
I 07/26/24 11:46:50 00435 ports: port 3 is Blocked by AAA
I 07/26/24 11:46:35 00077 ports: port 3 is now off-line
I 07/26/24 11:44:38 00076 ports: port 3 is now on-line
I 07/26/24 11:44:38 00435 ports: port 3 is Blocked by STP
I 07/26/24 11:44:02 00435 ports: port 3 is Blocked by AAA
I 07/26/24 11:43:57 00077 ports: port 3 is now off-line
I 07/26/24 11:42:17 00076 ports: port 3 is now on-line
I 07/26/24 11:42:17 00435 ports: port 3 is Blocked by STP
I 07/26/24 11:42:08 00435 ports: port 3 is Blocked by AAA
I 07/26/24 11:42:06 00077 ports: port 3 is now off-line
I 07/26/24 11:42:06 00435 ports: port 3 is Blocked by AAA
I 07/26/24 11:42:04 00077 ports: port 3 is now off-line
I 07/26/24 11:42:04 00435 ports: port 3 is Blocked by AAA
I 07/26/24 11:42:03 00077 ports: port 3 is now off-line
I 07/26/24 11:38:54 00076 ports: port 3 is now on-line
I 07/26/24 11:38:54 00435 ports: port 3 is Blocked by STP
I 07/26/24 11:38:53 00435 ports: port 3 is Blocked by AAA
I 07/26/24 11:38:42 00077 ports: port 3 is now off-line
I 07/26/24 11:37:32 05385 auth: mac-pinning is enabled on port 3 for mac-based
I 07/26/24 11:36:38 00435 ports: port 3 is Blocked by AAA
I 07/26/24 11:30:51 05385 auth: mac-pinning is disabled on port 3 for mac-based
These are logs for port 3 since I disabled and enable aaa auth
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/4c6a4ecef37341789c264a2b040e3f9c.png)
Another printer model is working fine, but we have more like this one.
