MAC Auth and Profiling Static IP Devices
  • 1.  MAC Auth and Profiling Static IP Devices
    Posted Jan 15, 2015 07:58 PM
    Is there any documentation/tutorials that walks you through how to do MAC authentication on non 802.1x devices that have static IP addresses?  I am looking to build a MAC Auth service that will profile various devices (PLCs, cameras, routers, video decoders) and put them onto the private network, and force non 802.1x computers (Guest visitors/vendros) to an internet only VLAN.
    Is there any docs that show how to build such a service?  I understand there are various to profile a device (NMAP, SNMP, NESUS, MAC OUI), but how do you use these methods in a service?
    Thanks for your help ahead of time.
    Mark
  • 2.  RE: MAC Auth and Profiling Static IP Devices
    Posted Jan 15, 2015 08:06 PM
    Does this help?
  • 3.  RE: MAC Auth and Profiling Static IP Devices
    Posted Jan 15, 2015 10:22 PM
    Thanks Tim.  It does help, but I am not sure what the enforcement profile (ROLE_PROFILE) look like.  If not too much trouble, can you show how that profile is built? I am looking to see how the device is profiled and can be classified as a certain type of device.  There must something else that needs configured to determine the device type.  I would assume if you used SNMP or NMAP that there is configurations that can read into a response to determine the device type.
    Am I even in the ballpark on this works?
    Thanks again for taking the time to show me the screenshots above.
  • 4.  RE: MAC Auth and Profiling Static IP Devices
    Posted Jan 15, 2015 10:27 PM
    The profile role is just a controller role that only allows DHCP only. This allows profiling to occur and then once ClearPass gets the initial profile, it will bump the user so that they can authenticate against other rules in your enforcement policy.
    Same idea with nmap. You can give the device an audit state based on rules you set. So you could give temporary Internet only access until a device was audited or profile and then change the devices role.
    There will be some additional profiling options in the upcoming 6.5 release so stay tuned for that.
    Tim
  • 5.  RE: MAC Auth and Profiling Static IP Devices
    Posted Jan 16, 2015 07:42 AM
    Thanks Tim,
    I am just trying to understand how to use something like the NMAP feature to further profile and change the access of a static device.
  • 6.  RE: MAC Auth and Profiling Static IP Devices
    Posted Jan 16, 2015 11:22 AM
    With MAC AUTH is there a way to give different device types different network access.  For example:
    If I have an Security camera using MAC auth, can I allow it to connect to the internal network VLAN A, and then have guest user's PC using MAC AUTH and configure them to use VLAN B.
    If so, how do you get the device profiled to know if it is a security camera versus a guest PC?
  • 7.  RE: MAC Auth and Profiling Static IP Devices
    Posted Jan 16, 2015 11:34 AM
    This is done via DHCP profiling. Do you have helper addresses configured to point to ClearPass?
    Once the device is profiled, you map the device category/family/device name (derived from the profile) to an enforcement profile. The enforcement profile(s) are what get sent down to the switch/controller.
    This is what's shown in the second to last screenshot above.
    Tim
  • 8.  RE: MAC Auth and Profiling Static IP Devices
    Posted Jan 16, 2015 12:09 PM
    Thanks Tim.  That is my problem the endpoint is not getting profiled.  It is a static IP address device.  It will never send a DHCP request.  I have the helper-address pointing to ClearPass and that works well for PCs and other devices doing DHCP.
    How do you get a static IP address device profiled?
  • 9.  RE: MAC Auth and Profiling Static IP Devices
    Posted Jan 16, 2015 12:13 PM
  • 10.  RE: MAC Auth and Profiling Static IP Devices
    Posted Jan 16, 2015 12:19 PM
    Tim, I have seen this doc, but doesn't help my situation with something like a PLC (Programmable Logic Controller).    But the PLC does support SNMP.  Isn't there a way to have CPPM query the endpoint via SNMP (public) to get back info to profile it.  I am looking for seomthing like this.  Is that possible or am I barking up the wrong tree?
    I am trying to determine if there are automated ways to profile static IP address devices immediately when they connect, or am I going to have to maintain some sort of Static Host Table.
    Doesn't the subnet scan happen at pre-defined time intervals?
  • 11.  RE: MAC Auth and Profiling Static IP Devices
    Posted Jan 18, 2015 10:37 PM
    You can enable the audit feature on the service which can run NESSUS or nmap scans against the device and then bump it off so it can reauthenticate.
    In the configuration for NESSUS and/or nmap, you can write rules that map certain information returned by the scan to a ClearPass role which you can use in your enforcement to make a decision.
  • 12.  RE: MAC Auth and Profiling Static IP Devices
    Posted Jan 18, 2015 10:52 PM
    Thanks for your help Tim.  I will check this out tomorrow.  Are there any docs out there that show the kinds of attributes that can be mapped to roles?  Also, is there anyway to see a debug of the returned nmap scan to know what data is there to work with?
  • 13.  RE: MAC Auth and Profiling Static IP Devices
    Posted Dec 20, 2017 09:16 AM
    I know this topic is from 2 years ago. I have same needs, but as Clearpass is not aware of the IP address of the device, i don't see how the NMAP is going to work to do the scan.
    Any ideas on how proceed in this case?
    Thanks!
