mac authentication
This thread has been viewed 23 times
  • 1.  mac authentication
    Posted Apr 15, 2017 06:20 PM
    Hi , everybody
    could you help me by steps how can i handle the mac authentication in clear pass for the non supplicant devices like printers , phones , camera
    thanks
  • 2.  RE: mac authentication
    Posted Apr 16, 2017 05:15 AM
    Hi. What version of ClearPass are you running? If 6.6 have a read of the OnConnect feature. Its ideal for this scenario
  • 3.  RE: mac authentication
    Posted Apr 16, 2017 05:50 AM
    What type of switch?
    Are you looking to manually register the devices or automatically control access using profile data?
  • 4.  RE: mac authentication
    Posted Apr 17, 2017 03:24 AM
    Hi
  • 5.  RE: mac authentication
    Posted Apr 17, 2017 03:30 AM
    We will need more information first. Onconnect may not be the answer here. See tims questions above. Also how are the devices connecting. Wired/wireless? What vendor are the switches, controllers etc
  • 6.  RE: mac authentication
    Posted Apr 17, 2017 03:42 AM
    Hi,guru
    my network is very simple contains brocade icx 6450 switchs and aruba controller and i'm looking for a method to combine between the username and the machine (dual authentiocation ) i,e every user can access the network via known PC
    could you help me to get the setps of the solution ? wired and wirless
    thanks alot
  • 7.  RE: mac authentication
    Posted Apr 17, 2017 03:54 AM
    There is quite a bit that you are asking to do. Are you working with a partner or an aruba SE?
    I would first start on the wireless side and then move to wired. This Guide will get you start but won't be an exact fit.
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=10345
  • 8.  RE: mac authentication
    Posted Apr 17, 2017 04:11 AM
    thanks alot for your quick response , i 'm working with aruba partner , thanks for wirless sol and waiting for the wired solution
    thank you
