MAC Authentication accepted but captive portal keeps popping up
  • 1.  MAC Authentication accepted but captive portal keeps popping up
    Posted Jul 27, 2018 04:31 AM
    Hey
    I have a guest portal that works in every way with phone number as username and SMS as code on initial login. I have 6 months as Mac auth expiry.
    My problem is when MAC authentication is performed the next day when a user is trying to connect, it gets accept and the cppm user role is assigned, but the captive portal pops up on for example a Apple Iphone.
    Can anyone help me out ?
  • 2.  RE: MAC Authentication accepted but captive portal keeps popping up
    Posted Jul 27, 2018 07:42 AM
    Did you use the Mac caching wizard in ClearPass to build your services/policies/profiles?
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: MAC Authentication accepted but captive portal keeps popping up
    Posted Jul 27, 2018 07:48 AM
    Yes, I think it fails here:
    it should hit the first-applicable which is "[Allow Access Profile], [GUEST Guest Profile]", but it goes to the next enforcment profile "[Allow Access Profile], [GUEST Captive Portal Profile]". I just cannot understand why.
  • 4.  RE: MAC Authentication accepted but captive portal keeps popping up
    Posted Jul 27, 2018 08:28 AM
    Can you share the post-auth profile (Guest Mac Caching Profile) assigned under the mac caching service
    Also can you share the role mapping for the mac authentication service
  • 5.  RE: MAC Authentication accepted but captive portal keeps popping up
    Posted Aug 06, 2018 06:04 AM
    Sorry for late reply.
    Here are post-auth profile (Guest Mac Caching Profile):
    Here are role mapping for the mac authentication service:
  • 6.  RE: MAC Authentication accepted but captive portal keeps popping up
    Posted Aug 06, 2018 06:26 AM
    I see this now:
    Are this value set by the orginal form: guest_register with the field: expire_afer ?
  • 7.  RE: MAC Authentication accepted but captive portal keeps popping up
    Posted Aug 07, 2018 06:15 AM
    When removing the following from the generated guest-mac-policy:
    AND(Authorization:[Guest User Repository]:AccountExpired EQUALS false)
    AND(Authorization:[Guest User Repository]:AccountEnabled EQUALS true)
    Then everything works as expected. Users who never have authenticated get captive portal, users with the mac-expiry-auth value set gets mac authentication.
