MAC authentication failures
  • 1.  MAC authentication failures
    Posted Jun 25, 2012 07:47 AM
    I am experiencing mac authentication failures with the following log message:
    Jun 25 12:35:12  authmgr[1836]: <522049> <INFO> |authmgr|  MAC=ac:81:12:03:b0:70,IP=169.254.228.79 User role updated, existing Role=ap-role/ap-role, new Role=ap-role/ap-role, reason=User not authenticated for inheriting attributes
    We are using an external RADIUS server for authentication and are successfully authenticating via 802.1x on a seperate SSID. Also we have a third SSID for mac-authh using the controllers internal DB successully. The controller was successfully authenticating mac-auth to the external RADIUS box at one time, and nothing has changed on the radius or controller either. The only recent change to the master controller that may have affected things was a PEFNG license was applied then removed as it was not present on the Local controller. Could this have effected the AAA profile, even though it has reverted back to its original state?
    Please can I request some assistance?
    Vik
  • 2.  RE: MAC authentication failures
    Posted Jun 25, 2012 08:05 AM
    Make sure you only have a mac authentication profile in the AAA profiles that you want.
  • 3.  RE: MAC authentication failures
    Posted Jun 25, 2012 08:35 AM
    Yes, we only have MAC auth configured in the AAA profile and are NOT doing mixed mode authentication on the MAC-auth SSID.
    Vik
  • 4.  RE: MAC authentication failures
    Posted Jun 25, 2012 08:37 AM
    Check the other AAA profiles and make sure you do NOT have mac authentication profile enabled for those.
  • 5.  RE: MAC authentication failures
    Posted Jun 26, 2012 04:45 AM
    I have checked the other AAA profiles and confirm that the mac auth profile is not enabled on them.
    Vik
  • 6.  RE: MAC authentication failures
    Posted Jun 26, 2012 06:24 AM
    Sorry,
    That is not a mac authentication failure message.
