MAC Authentication per SSID using Internal Server
  • 1.  MAC Authentication per SSID using Internal Server
    Posted Nov 29, 2017 05:32 AM
    I'm working on a project using IAP 215, OS version 6.4.4.8-4.2.4.6_58505.
    I have two employee networks using MAC authentication. Let's say SSID A and SSID B.
    I'm using the IAP internal server to register the allowed client MAC adresses.
    My problem is that allowed MAC adress for SSID A are able to access SSID B and vice versa.
    Is there any way I could assigned an authorized MAC to a single SSID and still use the IAP internal server ?
  • 2.  RE: MAC Authentication per SSID using Internal Server
    Posted Nov 29, 2017 06:29 AM
  • 3.  RE: MAC Authentication per SSID using Internal Server
    Posted Nov 30, 2017 05:40 AM
    Thank you for your answer,
    I did not think about that but it's quite smart and it works great !
