Mac-authentication without.1x
  • 1.  Mac-authentication without.1x
    Posted Mar 23, 2017 07:02 AM
    i want to do MAC authentication by selecting security option WAP2 with AES.
    but while selecting WAP2+AES it is asking to create .1x profile.. if i create .1x profile  and try to connect with the AP first it check MAC if authenticated then a window POP up for usename and Password.
    i want to by pass username and password while Mac authentication with WPA2+AES.
  • 2.  RE: Mac-authentication without.1x
    Posted Mar 23, 2017 07:17 AM
    Is this a controller or instant ?
    Get Outlook for iOS
  • 3.  RE: Mac-authentication without.1x
    Posted Mar 23, 2017 07:19 AM
    Controller.
  • 4.  RE: Mac-authentication without.1x
    Get Outlook for iOS
  • 5.  RE: Mac-authentication without.1x
    Posted Mar 23, 2017 07:18 AM
    Controller
  • 6.  RE: Mac-authentication without.1x
    Is this Aruba Instant?
  • 7.  RE: Mac-authentication without.1x
    Posted Mar 23, 2017 07:20 AM
    Hi joseph.
    its controller
  • 8.  RE: Mac-authentication without.1x
    Posted Mar 23, 2017 07:51 AM
    In the controller you need to select
    WPA2 / PSK AES
    You need to the following to the aaa profile :
    Mac auth profile (under authentication > Layer 2 auth > Mac auth profile )
    802.1x auth profile (under authentication > Layer 2 auth > psk profile)
    Mac auth server group (select the internal controller or external servers)
    Get Outlook for iOS
  • 9.  RE: Mac-authentication without.1x
    Posted Mar 23, 2017 08:07 AM
    hi.
  • 10.  RE: Mac-authentication without.1x
    WPA2 / PSK AES
    Get Outlook for iOS
  • 11.  RE: Mac-authentication without.1x
    Posted May 04, 2017 03:48 AM
    I need aruba 3200 image to be installed in my VM machine.
    Can Any one share the link for the same . as i am getting mobility master image only
  • 12.  RE: Mac-authentication without.1x
    Posted May 04, 2017 05:18 AM
    Hi Rohit,
    8.x is not supported for 3200 platform
  • 13.  RE: Mac-authentication without.1x
    Posted May 04, 2017 05:29 AM
    Can you please share link for 7200 Series ISO image for VM
  • 14.  RE: Mac-authentication without.1x
    Posted May 04, 2017 10:10 AM
    Hi Rohit,
    There is no iso image for any 72xx or 70xx platform.
    There are direct VM based images available on support site.
    https://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/EntryId/25078/Default.aspx
    Please click on the above link to login in to support site & download the required image.
