last person joined: 9 hours ago
Mac book user+machine auth/ user+mac auth
  • 1.  Mac book user+machine auth/ user+mac auth
    Posted Oct 16, 2015 08:13 AM
    HI,
    I am using User + Machine auth. for windows user and that is woring fine (SSID : Employee). Using self signed certificate.
    Now i have Mac book and they are the part of windows domain.
    Can i use same SSID & enforcement policy for Mac Book? or if i add one more rule in the same enforcement policy --> User + mac auth.(static host list)
    If not please suggest alternate more secure solution.
    Thanks in advance...
  • 2.  RE: Mac book user+machine auth/ user+mac auth
    Posted Oct 16, 2015 08:15 AM
    Yes, you can but it's a much more complex authentication as Macs do not natively perform machine authentication.
    How are you managing your Macs? Profile manager or an MDM?
    Tim
  • 3.  RE: Mac book user+machine auth/ user+mac auth
    Posted Oct 16, 2015 08:29 AM
    Thanks for quick reply....
    for system mac, i will use CPPM static host list.
    Nik..
  • 4.  RE: Mac book user+machine auth/ user+mac auth
    Posted Oct 16, 2015 08:31 AM
    You can only use MAC address as an authorization. The device still needs a machine credential to authenticate.
    How are you managing the devices?
    Tim
  • 5.  RE: Mac book user+machine auth/ user+mac auth
    Posted Oct 16, 2015 08:37 AM
    I will use windows AD for Mac book authentication.
  • 6.  RE: Mac book user+machine auth/ user+mac auth
    Posted Oct 16, 2015 08:38 AM
    How are you managing your devices? You need to be able to push a network profile down (or manually install on every single device)
    Tim
  • 7.  RE: Mac book user+machine auth/ user+mac auth
    Posted Oct 16, 2015 08:47 AM
    Enforcement profile policy will push  vlan info to authenticated + authorize users.
    Please correct if i wrong..
  • 8.  RE: Mac book user+machine auth/ user+mac auth
    Posted Oct 16, 2015 08:52 AM
    You need a custom configuration profile installed on the devices to be able to do Machine + User authentication.
    Tim
  • 9.  RE: Mac book user+machine auth/ user+mac auth
    Posted Oct 16, 2015 09:08 AM
    i can't do that on all mac book. Is there any alternate authentication method i can use instead of machine authentication?
  • 10.  RE: Mac book user+machine auth/ user+mac auth
    Posted Oct 16, 2015 09:10 AM
    You're not managing the devices?
    User authentication with MAC address authorization or Onboard would be the alternatives.
    Tim
  • 11.  RE: Mac book user+machine auth/ user+mac auth
    Posted Oct 29, 2015 02:42 AM
    I have added new rule in the same enforcement profile using static host list. Add static host list group in authontication server list.
    Nik..
