Mac Cache
  • 1.  Mac Cache
    Posted Dec 14, 2014 11:24 PM
    I’ve got a guest SSID setup on a controller redirecting to a webpage on Clearpass. I have Mac Caching enabled, well at least I thought I did. The Mac are not registering/populating the database so something must be a miss. Any advice on where to look or clear cut instructions for setting that up?
    Thxs
  • 2.  RE: Mac Cache
    Posted Dec 14, 2014 11:39 PM
    What I suggest you do is create your Mac Caching services using the ClearPass templates "Guest Mac Authentication"
    In the controller make sure you have the following :
    - Cleapass as you mac authentication server source
    - Add a Mac Auth L2 profile
    - Enable Accounting in the aaa profile
    - And ClearPass as your RFC 3576
  • 3.  RE: Mac Cache
    Posted Feb 04, 2015 08:33 PM
    victor, how do I do this with Instant APs?
  • 4.  RE: Mac Cache
    Posted Feb 04, 2015 08:35 PM
    From the ClearPass side, there is no difference.
    To configure MAC-authentication on Instant:
    http://www.arubanetworks.com/techdocs/Instant_41_Mobile/Advanced/Content/UG_files/Authentication/MAC_Authentication.htm?SearchType=Stem
  • 5.  RE: Mac Cache
    Posted Feb 04, 2015 10:39 PM
    I would assume the MAC Cache service needs to be before the auth service or does it matter?
  • 6.  RE: Mac Cache
    Posted Feb 04, 2015 10:48 PM
    It just logically makes sense to have it before your web auth service since that's the order it's processed.
    Tim
  • 7.  RE: Mac Cache
    Posted Dec 16, 2014 10:08 AM
    Try a few things
    Verify that MAC-Auth is triggered in the Access Tracker. Follow Victors instructions if they don't show there.
    Enable Insight under Server Configuration
    On you login-page select "Update Endpoint"
    Verify again through access-tracker that mac-auth is triggered.
