Mac caching and unknown Endpoint
  • 1.  Mac caching and unknown Endpoint
    Posted Oct 11, 2016 02:31 PM
    Hello Community.
    I have a customer how wants to authorize his clients manualy. For that i check in the service if the endpoint is known and we use PEAP. He manualy marks the endpoints as know. That works fine for him.
    Now we have a problem with mac caching. When a guest logs in the Wifi the Guest is marked as a known device that mac caching works. When i remove the update endpoint from the enforcement policy mac caching is no longer working.
    Does anybody has a idea how to realize that?
    Regards Stefan
  • 2.  RE: Mac caching and unknown Endpoint
    Posted Oct 11, 2016 02:33 PM
    I'd recommend you look at using the Guest Device Repository for handling
    known device registration.
  • 3.  RE: Mac caching and unknown Endpoint
    Posted Oct 11, 2016 03:48 PM
    Hello, that sounds good. But i don´t understand how i can add a device in Guest User Repository and how can i check this? In CPPM i find nothing.
  • 4.  RE: Mac caching and unknown Endpoint
    Posted Oct 11, 2016 03:50 PM
    Under guest, go to Create Device.
  • 5.  RE: Mac caching and unknown Endpoint
    Posted Oct 11, 2016 03:53 PM
    Ok, but is it possible to create this automaticly when the guest is authenticaed?
  • 6.  RE: Mac caching and unknown Endpoint
    Posted Oct 11, 2016 03:56 PM
    Sorry, looks like we're talking about different things.
    You don't have to mark guests as Known. Instead you can change your
    MAC-caching service to do Allow All MAC-Auth and remove the Update Endpoint
    Known action.
  • 7.  RE: Mac caching and unknown Endpoint
    Posted Oct 11, 2016 04:20 PM
    I think so. Ok, i have to create a new enforcement Profile an allow all Mac? Is that also a Post_Authentication Endpoint Atribute?
  • 8.  RE: Mac caching and unknown Endpoint
    Posted Oct 11, 2016 04:34 PM
    No, it's the authentication method in your MAC-Auth service.
  • 9.  RE: Mac caching and unknown Endpoint
    Posted Oct 11, 2016 04:44 PM
    Ok, this is at the moment at Endpoint Repository. And i have to change it to?
  • 10.  RE: Mac caching and unknown Endpoint
    Posted Oct 11, 2016 05:08 PM
    That should be the auth source. Above that, you should have Auth Methods.
    Remove MAC Auth and replace with Allow All MAC Auth
  • 11.  RE: Mac caching and unknown Endpoint
    Posted Oct 11, 2016 05:38 PM
    Perfekt. It works.
    Thank you very much :)
    Regard Stefan
