MAC caching - failed to get value for attributes
This thread has been viewed 32 times
  • 1.  MAC caching - failed to get value for attributes
    Posted Sep 05, 2017 09:12 AM
    I'm trying to setup guest login with MAC caching using the template, but I keep getting following error in access tracker.
    Policy serverFailed to get value for attributes=[AccountEnabled, AccountExpired]
     When I delete the check for AccountEnabled and AccountExpired, it works fine and the MAC gets cached.
    Insight is enabled.
    The endpoint is known and in the endpoint repo, the Authorization contains Endpoint repo, time source and Guest user repo.
    All is done via the template, so I don't know where to start.
    We are using 1 user for about 200-300 devices,  but that is working fine.
  • 2.  RE: MAC caching - failed to get value for attributes
    Posted Sep 05, 2017 09:15 AM
    Is [Guest User Repository] set up as an additional authorization source?
  • 3.  RE: MAC caching - failed to get value for attributes
    Posted Sep 05, 2017 09:17 AM
    Yes
  • 4.  RE: MAC caching - failed to get value for attributes
    Posted Sep 05, 2017 09:24 AM
    Please share a screenshot of the access tracker request and also your service configuration.
  • 5.  RE: MAC caching - failed to get value for attributes
    Posted Sep 05, 2017 09:44 AM
    Output from access tracker:
    Username:
    28b2bdb2a093
    End-Host Identifier:
    28B2BDB2A093
    (Computer / Windows / Windows)
    Access Device IP/Port:
    192.168.58.34:0
    (wanaka.genk.be / Aruba)
    RADIUS Request
    Radius:Aruba:Aruba-AP-Group
    apgrp_thorpark
    Radius:Aruba:Aruba-Essid-Name
    Thor Central
    Radius:Aruba:Aruba-Location-Id
    c8:b5:ad:c4:10:a6
    Radius:IETF:Called-Station-Id
    000B86B7F4F7
    Radius:IETF:Calling-Station-Id
    28B2BDB2A093
    Radius:IETF:NAS-IP-Address
    192.168.58.34
    Radius:IETF:NAS-Port
    0
    Radius:IETF:NAS-Port-Type
    19
    Radius:IETF:Service-Type
    10
    Radius:IETF:User-Name
    28b2bdb2a093
    Authorization Attributes
    Authorization:[Endpoints Repository]:Unique-Device-Count
    1
    Authorization:[Time Source]:Now DT
    2017-09-05 11:00:00
    Authorization:[Time Source]:One Day DT
    2017-09-06 11:00:00
    Authorization:[Time Source]:One Month DT
    2017-10-05 11:00:00
    Authorization:[Time Source]:One Week DT
    2017-09-12 11:00:00
    Authorization:[Time Source]:Six Months DT
    2018-03-05 11:00:00
    Computed Attributes
    Authentication:ErrorCode
    0
    Authentication:Full-Username
    28b2bdb2a093
    Authentication:Full-Username-Normalized
    28b2bdb2a093
    Authentication:MacAuth
    KnownClient
    Authentication:OuterMethod
    MAC-AUTH
    Authentication:Posture
    Unknown
    Authentication:Source
    Authentication:Status
    MAB
    Authentication:Username
    28b2bdb2a093
    Authorization:Sources
    [Guest User Repository], [Endpoints Repository], [Time Source]
    Connection:AP-Mac
    c8b5adc410a6
    Connection:AP-Name
    c8b5adc410a6
    Connection:Client-Mac-Address
    28B2BDB2A093
    Connection:Client-Mac-Address-Colon
    28:b2:bd:b2:a0:93
    Connection:Client-Mac-Address-Dot
    28b2.bdb2.a093
    Connection:Client-Mac-Address-Hyphen
    28-b2-bd-b2-a0-93
    Connection:Client-Mac-Address-NoDelim
    28b2bdb2a093
    Connection:Client-Mac-Address-Upper-Hyphen
    28-B2-BD-B2-A0-93
    Connection:Client-Mac-Vendor
    Intel Corporate
    Connection:Dest-IP-Address
    192.168.58.30
    Connection:Dest-Port
    1812
    Connection:NAD-IP-Address
    192.168.58.34
    Connection:Protocol
    RADIUS
    Connection:Src-IP-Address
    192.168.58.35
    Connection:Src-Port
    42219
    Connection:SSID
    Thor Central
    Date:Date-Time
    2017-09-05 11:02:41
    Endpoint:Guest Role ID
    1
    Endpoint:Last Known Authentication Type
    wireless
    Endpoint:Last Known Device
    AP: a8:bd:27:c5:e5:46
    Endpoint:Last Known SSID
    Thor Central
    Endpoint:MAC-Auth Expiry
    2017-09-07 23:59:00
    Endpoint:Username
    PWC2TC, PWC2TC
     Overview:
    Enforcement (pretty straight forward)
    Mapping:
  • 6.  RE: MAC caching - failed to get value for attributes
    Posted Sep 05, 2017 09:57 AM
    Your configuration looks correct. Best to open a TAC case so they can troubleshoot in realtime.
  • 7.  RE: MAC caching - failed to get value for attributes
    Posted Sep 06, 2017 03:56 AM
    Not sure where you got this Role Mapping from.
    The problem here is that the Guest User Repository is based on username, where the MAC Authentication service is based on MAC address. The attributes AccountEnables and AccountExpired are on the username.
    You only map those in the captive portal service, which is on username; and have a separate mapping on the MAC Authentication service for MAC Caching.
    What may help, is to have a look at this workshop video series, where in the Guest part a service, including MAC Caching is created.
    For the MAC Caching, only the endpoint repository is queried in the role-mapping:
    (Authorization:[Endpoints Repository]:Unique-Device-Count  EXISTS  )
    AND (Authorization:[Time Source]:Now DT  LESS_THAN  %{Endpoint:MAC-Auth Expiry})
    AND (Authorization:[Guest User Repository]:AccountExpired  EQUALS  false)
    AND (Authorization:[Guest User Repository]:AccountEnabled  EQUALS  true)
    [MAC Caching]
    That field MAC-Auth Expiry is set in the captive portal authentication:
    Endpoint MAC-Auth Expiry = %{Authorization:[Guest User Repository]:ExpireTime}
    So please check your policies, and where you got them from. To me, it looks like you can just remove the two lines that check the Guest User Database. However, that check needs to be done in the Captive Portal service, so make sure you have that rules in place (with separate role-mapping).
  • 8.  RE: MAC caching - failed to get value for attributes
    Posted Sep 06, 2017 04:43 AM
    The strange thing is, that this service is created by the template, so where does this come from?
    Even your web video shows the exact same in Guest #2, timestamp https://youtu.be/o6ZrDmSMMOU?t=444
  • 9.  RE: MAC caching - failed to get value for attributes
    Posted Sep 06, 2017 04:52 AM
    Let me check that again in my lab.
  • 10.  RE: MAC caching - failed to get value for attributes
    Posted Sep 06, 2017 05:51 AM
    Have you changed the variables or attributes in the Guest module?
    For me it looks like it can't resolve the field that it is using as the username
  • 11.  RE: MAC caching - failed to get value for attributes
    Posted Sep 06, 2017 05:54 AM
    Endpoint:Username
    PWC2TC, PWC2TC
    Your Access-Tracker log shows two usernames for this device. Should only show one from my understanding
  • 12.  RE: MAC caching - failed to get value for attributes
    Posted Sep 06, 2017 06:12 AM
    Field Label Value Display id   username Username: current_state Current State: do_expire Expire Action: email Email Address: enabled Account Status: expired_notify_status Expired Notification: expire_postlogin Account Lifetime: expire_time Expiration Time: notes Notes: remote_addr Create Address: role_id Account Role: role_name Account Role: simultaneous_use Session Limit: source Create Source: sponsor_name Sponsor’s Name: sponsor_profile   sponsor_profile_name Sponsor’s Profile: start_time Activation Time: visitor_carrier Mobile Carrier: visitor_company Company Name: visitor_name Guest’s Name:
    32213221
    PWC2TCPWC2TC
    activeActive
    1Disable at specified time
    xxxx.bexxxx.be
    1Enabled
    11
    0
    1504821540Thursday, 07 September 2017, 11:59 PM
    PWC account for multiple usersPWC account for multiple users
    172.17.22.249172.17.22.249
    11
    ROLE GuestROLE Guest
    00
    create_usercreate_user
    gg
    11
    Super AdministratorSuper Administrator
    15045264572017-09-04 14:00
    PWCPWC
    PWC2TCPWC2TC
  • 13.  RE: MAC caching - failed to get value for attributes
    Posted Sep 06, 2017 06:39 AM
    Please check the endpoint database for this client device. Is the username listed in this endpoints entry?
  • 14.  RE: MAC caching - failed to get value for attributes
    Posted Sep 06, 2017 08:03 AM
    Yes, the username is filled in, however it has 2 entries, twice the same
  • 15.  RE: MAC caching - failed to get value for attributes
    Posted Sep 06, 2017 10:04 AM
    I just retried this scenario in lab, and I see the attributes in the Access Tracker:
    Authorization:[Endpoints Repository]:Unique-Device-Count 1
    Authorization:[Guest User Repository]:AccountEnabled true
    Authorization:[Guest User Repository]:AccountExpired false
    It appears that the username for the lookup in the Guest User Repository is pulled from the Endpoint Database:Username field.
    Endpoint Username = %{Authentication:Username}
    Can you go back to the enforcement profile that sets this value, and check Access Tracker on why it puts the username in twice? Of you look up the account information with a garbled username, I can imagine that it will post errors (and not work).
  • 16.  RE: MAC caching - failed to get value for attributes
    Posted Sep 07, 2017 10:25 AM
    I just deleted the 2 services and created again using the template wizard + deleted all endpoint associated with the guest ssid, and now it works...
