Mac caching social media with azure issue
  • 1.  Mac caching social media with azure issue
    Posted Jul 14, 2017 04:05 PM
    Hello i got 2 SSIDS
    1 SSID  Xis binded to an Azure  which the domain is @domain1.com
    1 SSID  Y is binded to an azure which the domain is @domain2.com
    now if igot the mac caching i got a single endpoint repository
    The problem i got is that if the user do the mac authentication they can log in, in any of those ssids, as they are doing mac authetnication and i dont have any way to differenciate them when doing mac authentication
    Anyone got any idea on how i can  maybe add an attribute or something that if the user connect to the ssid X just the users of the domain @domain1.com can connect to it and cannot connect to ssid Y
    And the users that connect to SSID Y just can connect to it if they are using the @domain2.com but cannot connect to SSID X when using mac caching?
    Cheers
    Carlos
  • 2.  RE: Mac caching social media with azure issue
    Posted Jul 14, 2017 04:12 PM
  • 3.  RE: Mac caching social media with azure issue
    Posted Jul 15, 2017 11:00 AM
    omg Tim thanks!
    It seems to work but ill run more test
    Also it solved me an issue that for some reason sometimes the user of@domain 1 could join the ssid of @domain2
    I just put another rule like that on those service and now it seems its totally blocking that so im happy.
    Like i said ill run more test to check this out if this is it!
    Thanks again! you saved me :)
    Cheers
    Carlos
