I want to set up MAC filtering on one of my Wi-Fi SSID's to allow only the mac address I enter. Is there a step by step guide on how to do this I have the 3200XM console 6.1.3.4 build?
Thank you for your help.
This KB article should help you out.
https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-1126
Tim
That should do it thanks.
I've tried following this but my test client won't grab a dhcp adderss from the correct address range. I specified a certain VLAN for the ssid and it's grabbing a DHCP address from VLAN whois IP range was supposedly firewalled off. Weird.
Hi guys
Could you share videos, how to do ? To many topics opened on this case. I read article but not same our aruba version. I tried but somethings went wrong.
ArubaOS (MODEL: Aruba650), Version 6.4.2.5
Regards
yes am having the same problem , I want to mac filter any employee who is using the wifi .. not only by the password .. but also with maz address , only devices with mac address which I manually entered can access my wifi , can I do this via aruba GUI ?
Is this for ArubaOS or Instant?
am using Aruba 7030 mobility controller .. I don't want to make a mac authentication profile coz I don't want a complicated thing , I just want employees to authenticate using WPA2 password but only specific mac addresses can successfully access the wifi .. as simple as that ! , I used to do this simple issue using normal wifi routers .
There is no other way to do this without a mac authentication profile: http://community.arubanetworks.com/t5/Controller-Based-WLANs/How-do-I-configure-MAC-based-authentication-on-Aruba/ta-p/182430
This does not happen with Aruba 7205s you are talking about. Is there a solution for this?
