mac filtering?
  • 1.  mac filtering?
    Posted Feb 10, 2012 02:05 PM
    I have an aruba 3600 with a remote ap connected in bridge mode.  Is it possible to create a mac filter that will only let specific mac addresses authenticate to the remote ap-105? I also have an aruba 620 with a campus ap attached that I would like to do the same thing with... If so how does one accomplish it?
    #3600
  • 2.  RE: mac filtering?
    Posted Feb 10, 2012 02:11 PM
    The answer is yes.
  • 3.  RE: mac filtering?
    Posted Feb 10, 2012 06:08 PM
    I don't want to authenticate using mac address, I want to authenticate using wpa2.  I just want to filter which ones are allowed to use wpa2 psk.   I did find that I could probably just create a mac policy and add each person's mac address that I want to allow.
  • 4.  RE: mac filtering?
    Posted Feb 10, 2012 11:01 PM
    The answer is, first create a wireless network or Virtual AP that allows you to do WPA2-PSK and get that working.  After that, go back into the AAA profile of that WLAN and add a mac authentication profile as well as a mac authentication server group.  That will add mac authentication to that WLAN.  If a devices does not pass mac authentication, it will simply not be able to get on.
    In 6.1 in the AAA profile there is a parameter called l2 failthrough, where if it does not pass mac authentication, it will then allow devices to get on using WPA2-PSK or 802.1x or whatever the SSID is configured for.
  • 5.  RE: mac filtering?
    Posted Feb 14, 2012 12:42 PM
    Do I add the list of mac addresses I want to allow in a mac policy or do I do that in the mac authentication server group server?
  • 6.  RE: mac filtering?
    There is a chapter in the user guided dedicated to Mac authentication.
