last person joined: 9 hours ago
  • 1.  MAC on IAP
    Posted Jul 14, 2015 02:43 PM
    What's the maximum simultaneous connected MAC address on a single IAP 275 ?
  • 2.  RE: MAC on IAP
    Posted Jul 14, 2015 11:21 PM
    Basically ( Not related to any manufacturer )  it's up to 254 MAC address (of associated & connected clients) per radio module per SSID per AP. (Dosent matter the AP type)
    We in Aruba set default setting as 64 (Instant and controller environment ) (you can change it if you would like) - it's make more sense :) and giving excellent client experience.
    I personally prefer not to pass 25 client devices per AP per SSID per radio module. (But also this is depends: site type,client needs,deployment method and more)
    LAST NOTE: on instant environment each VC group can handle up to 2048 clients
