MAC OSX 10.6.8 onboarding error
  • 1.  MAC OSX 10.6.8 onboarding error
    Posted Jan 08, 2014 11:44 PM
    While trying to onboard MAC OSX 10.6.8 the users are getting the following error in the quickconnect:
    “No Networks are defined for this operating system. Please contact your administrator. “
    Did anybody face this before and hopefully found a solution ? the network settings under onboarding settings is set with the correct config for onboarding all devices, nothing is disables
    Thanks in advanve for the help.
    Islam
  • 2.  RE: MAC OSX 10.6.8 onboarding error
    Posted Jan 08, 2014 11:55 PM
    Are any other devices having issues?
    Make sure you have it checkmarked in the provisioning profile.
  • 3.  RE: MAC OSX 10.6.8 onboarding error
    Posted Jan 08, 2014 11:58 PM
    I thought you would answer :D
    they are getting the page and able to download the app, once they run it and click next they get the msg i posted, under "network settings"  > protocols by defualt it is marked as PEAP with MSCHAPv2 for those, i;m using the default network settings profile, just created a new one and testing... hope it will work :'(
  • 4.  RE: MAC OSX 10.6.8 onboarding error
    Posted Jan 09, 2014 12:10 AM
    not working still :(
  • 5.  RE: MAC OSX 10.6.8 onboarding error
    Posted Jan 09, 2014 12:13 AM
    Are you having any issues with any other type of devices... IOS, Windows, Android
  • 6.  RE: MAC OSX 10.6.8 onboarding error
    Posted Jan 09, 2014 12:14 AM
    Nope all working perfectly fine, running 6.2.4
  • 7.  RE: MAC OSX 10.6.8 onboarding error
    Posted Jan 19, 2014 07:55 PM
    I have run into the same issue.
    It appears the latest version of Java (1.6.0_65) does extra checks when processing Quickconnect jar files; specifically Application, Permission and Codebase manifests in each file which appear to be missing
    As they are not in the jar files, Java fails to process the network configurations.
    Running OS X 10.6.8 with Java 1.6.0_24 does not encounter the issue and successfully Onboards.
    Worth checking if your issue is related to the same issue by checking the Java Console while running Quickconnect.
    Example of errors:
    Missing Application Name: manifest attribute for: https://hidden.com/onboard/quickconnect/2/QuickConnect.jar
    Missing Permissions manifest attribute for: https://hidden.com/onboard/quickconnect/2/QuickConnect.jar
    Missing Codebase manifest attribute for: https://hidden.com/onboard/quickconnect/2/QuickConnect.jar
  • 8.  RE: MAC OSX 10.6.8 onboarding error
    Posted Jan 19, 2014 11:06 PM
    Thanks a lot will try this and let you know how it goes.
  • 9.  RE: MAC OSX 10.6.8 onboarding error
    Posted Jan 27, 2014 08:40 AM
    I wasn't able to find that version of Java for 10.6.8., do you have a link for that please ?
  • 10.  RE: MAC OSX 10.6.8 onboarding error
    Posted Jan 27, 2014 04:53 PM
    Version 1.6.0_24 is what came on the Mac install disc.
    1.6.0_65 is after using Software Update to patch to the latest version.
  • 11.  RE: MAC OSX 10.6.8 onboarding error
    Posted Feb 02, 2014 03:27 AM
    Patch 5 released having a fix for this
  • 12.  RE: MAC OSX 10.6.8 onboarding error
    Posted Feb 02, 2014 04:01 AM
    Yes
  • 13.  RE: MAC OSX 10.6.8 onboarding error
    Posted Feb 02, 2014 07:18 PM
    I can confirm that patch 5 (6.2.5) resolves the issue.
    Thanks.
  • 14.  RE: MAC OSX 10.6.8 onboarding error
    Posted Mar 19, 2014 10:13 AM
    is this also fixed in 6.3.1 ?
