Wired Intelligent Edge
last person joined: 4 hours ago
MAC pinning on AOS-CX?
This thread has been viewed 82 times
  • 1.  MAC pinning on AOS-CX?
    Posted Aug 15, 2020 09:19 PM
    How is MAC Pinning enabled / configured on AOS-CX (specifically on 6300's).  We are on a mix of 10.04 & 10.05...
    I would go review the docs on ASP, but it is currently down for maintenance
  • 2.  RE: MAC pinning on AOS-CX?
    Posted Aug 16, 2020 02:05 PM
    Its under the port access role configuration. Using the keyword "none" provides the pinning as shown below
    access(config)# port-access role mytestrole
    access(config-pa-role)# client-inactivity timeout
    <300-4294967295> Set client inactivity timeout value in seconds.
    none Configure to not to remove the client due to inactivity
    access(config-pa-role)# client-inactivity timeout none
  • 3.  RE: MAC pinning on AOS-CX?
    Posted Aug 16, 2020 05:42 PM
    I had found the proper command earlier.
    We are using all Downloadable User-roles from ClearPass, so stuck it in the printer role there and we are good to go.
    Thank you!
  • 4.  RE: MAC pinning on AOS-CX?
    Posted Mar 15, 2024 08:28 AM
    Hello ,
    I also use clearpass with User-Roles. Can you tell me how you have done this ? That would be great!
    Thank you
  • 5.  RE: MAC pinning on AOS-CX?
    Posted Oct 20, 2022 07:54 AM
    Hello, how can I active this port-access role mytestrole on a port?
    Hartmut
  • 6.  RE: MAC pinning on AOS-CX?
    Posted Sep 05, 2023 03:35 PM
    Thanks for this I also added this command to my Printer DUR for ClearPass and am testing it now.
  • 7.  RE: MAC pinning on AOS-CX?
    Posted Mar 15, 2024 06:24 PM
    check this new technote about CX switch support for silent clients
