Macbook M1 has wifi issue with 802.11ac/n
  • 1.  Macbook M1 has wifi issue with 802.11ac/n
    Posted Aug 02, 2022 06:48 AM
    Hi all,
    I'm facing an issue with 802.11ac/n on Macbook M1. The issue occurs in the zone that has a lot of Macbook devices.
    The WiFi connection is totally unstable and users have experienced slower Internet speeds even if it shows good connection status, SNR is about 35-40 dB
    The download speed is around 10-20Mbps. AP 335 and 345.
    Everything is working properly when the users move to another zone (the download speed is 40-45Mbps)
    I have to disable VHT on ap group but It can be fixed only on other Macbooks but not on the Apple M1
    Below is the Macbook model:
    Macbook Pro 13-inch 2020
    CPU:1-Apple:M1 Chip:8-core;RAM:1-Apple:PC4-19200:16GB;Disk:1-Apple:SSD:256GB;Graphic:Apple M1 8 core GPU
    Does anyone have the same problem or any idea to fix it?
    Thanks in advance for the help.
  • 2.  RE: Macbook M1 has wifi issue with 802.11ac/n
    Posted Aug 04, 2022 07:52 AM
    Hello Tigerbt,
    There isn't any bandwidth restrictions in your SSID for that zone?
    What happens when you connect a different device, let's say a windows?
  • 3.  RE: Macbook M1 has wifi issue with 802.11ac/n
    Posted Aug 10, 2022 06:54 AM
    Hi Harrisb,
    There is no bandwidth restriction in the SSID profile. The issue occurs in Macbook high-density zone.
    When clients move to other floors (with no high-density Macbook), the speed is ok.
    I make a test on the same device with 2 zones.
    Thanks for your support.
  • 4.  RE: Macbook M1 has wifi issue with 802.11ac/n
    Posted Aug 04, 2022 10:44 AM
    If you search, there are many WiFi performance issues reported on Macs with the Apple CPUs. Few things that I found were that you could try to disable Bluetooth or make sure that you set a non-DFS channel.
    But indeed first make sure that the issue is only related to this Macbook and not to all clients on the same AP.
