Machine and User Authentication
  • 1.  Machine and User Authentication
    Posted Sep 27, 2012 07:06 PM
    Hello Collin
    Question regarding this
    If i got machine enforment on and also  EAP PEAP to athenticate with user and password
    I got it set up like this
    When you authenticate with the correct machine you  actually get an ip address but you get a deny all role
    When you authenticate the user then you get a derived role which got the real access.
    Now as i got it, it will affect the users that needs to change to a new password? i mean when they have a group policy  which tell you, that you need to change the password every X time?
    I did it this way because i want that it needed to pass both authentcation before having any access to the network.
    But it seems it will give me trouble...
    If im correct in what i thing
    To correct it what do you recommend?
    I was thinking in maybe that when it pass the machine authentication  it give you just the privileged to change the pasword... maybe just opening the ports that its needed for this agains the active directory ip address
    Or do you suggest another aproach?
    Thanks in advance
    Cheers
    Carlos
  • 2.  RE: Machine and User Authentication
    Posted Sep 30, 2012 03:44 AM
    I agree :)
  • 3.  RE: Machine and User Authentication
    Posted Oct 02, 2012 07:45 AM
    @NightShade1 wrote:
    Hello Collin
    Thanks in advance
    Cheers
    Carlos
    You need to pass machine authentication before you do anything.  Correct.
