Hi all,
We were configuring a few user laptops for user and machine authentication . User's laptop does not seem to do machine authention after rebooting a few times. As user laptop did not have the machine authenticated role, they were not allowed access to the wireless network. Anyone encountered a similar issue before? We are using clearpass as the radius for the controller.
Thanks.
Victor
User and machine authentication are both enabled in the Windows 1X configuration?
In Access Tracker, are you only seeing [User Authenticated] at that time?
Have you looked at the machine auth cache time ?
Yes, it should machine auth every time it reboots and also when you log out. The cache timer is set to 24 hours by default, so there is likely no issue there.
In access tracker, are you seeing the request with just a [User Authenticated] role?
so even at a reboot you don't see a machine auth request on the ClearPass?
i would check your windows settings then, it might be turned off somehow?
