Do you happen to know what setting that would be? I feel like i've tried every combination at this point. Here is what my current policy states:
Use Windows wireless LAN network services for clients -Enabled
Shared user credentials for network authentication - Enabled
Hosted networks - Enabled
Allow user to view denied networks - Enabled
Allow everyone to create all user profiles - Enabled
Only use Group Policy profiles for allowed networks - Disabled
Prevent connection to infrastructure networks - Disabled
Prevent connection to adhoc networks - Disabled
Preferred Network Profiles
Profile Name: corp_wifi
Network Type: Infrastructure
Automatically connect to this network - Enabled
Automatically switch to a more preferred network - Disabled
Authentication WPA2
Encryption AES
Use 802.1X Enabled
Pairwise Master Key (PMK) Caching Enabled
PMK Time-to-Live (minutes) 720
Number of Entries in PMK Cache 128
Maximum Pre-authentication Failures 3
Cache user information for subsequent connections to this network Disabled
Computer Authentication - Computer only
Maximum Authentication - Failures 3
Authentication method Protected EAP (PEAP)
Validate server certificate Disabled
Enable fast reconnect Enabled
Disconnect if server does not present cryptobinding TLV Disabled
Enforce network access protection Disabled
Authentication method Secured password (EAP-MSCHAP v2)
Automatically use my Windows logon name and password(and domain if any) Enabled
