last person joined: 7 hours ago
machine/user auth and accounting periodic update
  • 1.  machine/user auth and accounting periodic update
    Posted Jul 03, 2018 06:19 AM
    Hey!
    I have turned on user or computer authentication and it works fine.  Computer names and users are logged and given access from the policy manager - good news.
    However the gateway stops after a minute.  After using a stopwatch I saw that it always went off after precisely one minute.
    It is due to: aaa accounting update periodic 1 in the HP switch programming.
    Changing it to 5 gives you 5 minutes of internet.  I have removed this command.
    Is this normal? and do I need the command for other purposes?
  • 2.  RE: machine/user auth and accounting periodic update
    MVP
    Posted Jul 03, 2018 09:07 AM
    Instead of periodic, can you set accounting to start-stop instead?
    If your using ClearPass, RADIUS accounting is necessary for licensing (6.7) and to have proper Accounting data in ClearPass. You would also want RADIUS Interim-Accounting set to True in the server's RADIUS settings.
  • 3.  RE: machine/user auth and accounting periodic update
    MVP
    Posted Jul 03, 2018 09:09 AM
    In addition - the default should be 0 / disabled.
    HPE Networking: http://h22208.www2.hpe.com/eginfolib/networking/docs/switches/WB/15-18/5998-8152_wb_2920_asg/content/ch06s13.html
    Snippet from the link above:
    Syntax:
    [no] aaa accounting update periodic <1-525600>
    Sets the accounting update period for all accounting sessions on the switch.
    The no form disables the update function and resets the value to zero.
    Default: zero; disabled
  • 4.  RE: machine/user auth and accounting periodic update
    Posted Jul 03, 2018 09:20 AM
    Hi, Thanks for this
    I have Log Accounting Interim-Update Packets set to TRUE
    I had disabled/set to 0 the aaa accounting periodic update previously
    I have added:
    aaa accounting exec start-stop radius
    aaa accounting network start-stop radius
    to the switch programming - does it need both these commands for clearpass - assuming they are correct?
    Thank you for your help
  • 5.  RE: machine/user auth and accounting periodic update
    MVP
    Posted Jul 03, 2018 09:22 AM
    Exec would be for administration of the switch - console, ssh, telnet.
    Network would be for device authentications on the ports.
  • 6.  RE: machine/user auth and accounting periodic update
    Posted Jul 03, 2018 09:26 AM
    great, thanks for clearing that up I will go with
    then
  • 7.  RE: machine/user auth and accounting periodic update
    Posted Jul 03, 2018 11:00 AM
    Be sure to follow the ClearPass Solution Guide for Wired Policy Enforcement for fully validated configurations.
