MacOS Sierra VIA cannot connect
  • 1.  MacOS Sierra VIA cannot connect
    Posted Jun 14, 2017 03:41 AM
    I have installed "via" to my macbook pro computer running on MacOS Sierra. I'm trying to connect border.metu.edu.tr. The internet connection is my wireless internet in home. I see "Untrusted network" in the main screen of via, and cannot connect to the remote server. I can connect with a windows running desktop with the same wireless network and with the same settings.
    Do you have any advice rgarding to my problem?
    Thanks.
  • 2.  RE: MacOS Sierra VIA cannot connect
    Posted Jun 14, 2017 06:44 AM
    What version of VIA are you using on the mac?
  • 3.  RE: MacOS Sierra VIA cannot connect
    Posted Jun 14, 2017 06:47 AM
    Hello, I am using ver. 3.0.2
  • 4.  RE: MacOS Sierra VIA cannot connect
    Posted Jun 14, 2017 06:55 AM
    Ok.
    Find out what your public internet address is where your mac osx via client is.  Go to the controller and type "show datapath session table <public ip address>" and see if there is any traffic coming from your client when you try to start the connection.
  • 5.  RE: MacOS Sierra VIA cannot connect
    Posted Jun 14, 2017 07:33 AM
    Hi, Maybe a simple question but how can i open the controller? The following images i have only in the screen.
  • 6.  RE: MacOS Sierra VIA cannot connect
    Posted Jun 14, 2017 09:29 AM
    You should really reach out to your university's IT department.
