MacOS VIA Connection with EAP-TLS
  • 1.  MacOS VIA Connection with EAP-TLS
    Posted Feb 23, 2021 02:09 PM
    Hi, currently i'm working on Aruba VIA with MacOS and Windows. I already configured VIA connection profile to use EAP-TLS. It is working as expected for Windows, but somehow when we try to connect with MacOS we find an error. My question is there any additional configuration needs to be added to support MacOS? i tried to find it online but haven't got anything yet. Please help
    Here's some of the details :
    Mobility Master : 8.3.0.7
    Clearpass : 6.7.11
    MacOS : Catalina 10.15.7
    i attached the log from VIA Agent.
    Ananda Perdana
    Attachment(s)
    txt
    log.txt   48 KB 1 version
  • 2.  RE: MacOS VIA Connection with EAP-TLS
    Posted Feb 23, 2021 04:58 PM
    2021-02-23 12:36:53,733 ERROR - viaplugin_cert:findCertificateInStore:241 failed to find cert reference
    The required certificate could not be found.
    Tim C
  • 3.  RE: MacOS VIA Connection with EAP-TLS
    Posted Feb 26, 2021 03:40 AM
    Hi Tim,
    Thanks for the reply. I have checked that the client cert is already in KeyChain.
    i found this error log in the controller.
    Feb 26 14:30:33  isakmpd[3542]: <103063> <3542> <DBUG> |ike|   IKE2_delSa sa:0x1b59ce4 peer:118.99.107.65:63753 id:4082612045 err:-90036 saflags:a00051 arflags:1
    Feb 26 14:30:33  isakmpd[3542]: <103063> <3542> <DBUG> |ike|   IKE2_delSa: deleting IPSEC SA 118.99.107.65:63753 due to deletion of un-rekeyed IKE_SA
    Feb 26 14:30:33  isakmpd[3542]: <103102> <3542> <INFO> |ike|  IKE SA deleted for peer 118.99.107.65
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> udp_encap_handle_message ver:2 serverInst:0 pktsize:444
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE_EXAMPLE_IKE_msgRecv: ip:118.99.107.65  port:2563  server:0   len:444  numSkts:24
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE_EXAMPLE_IKE_msgRecv:1369: IKE2_msgRecv Called
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE2_msgRecv: dwPeerAddr: 76636b41 wPeerPort: a03
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> #RECV 444 bytes from 118.99.107.65(2563) at 10.232.12.11 (3745283.426)
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563->  spi={da4a525b68d8afe8 0000000000000000} np=SA
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563->  exchange=IKE_SA_INIT msgid=0 len=440
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE2_checkCookie notify-cookie ip:118.99.107.65
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IPSEC_findSaByIP addr:118.99.107.65
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IPSEC_findSaByIP pxSa:(nil) status:0
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IPSEC_findSaByIP finished with pxSa:(nil) status:0
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE2_checkCookie finished with ipsecSa:(nil) status:0
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> delete_cp_route entered with ip:118.99.107.65
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> controlplaneRouteModify entered with ip:118.99.107.65/255.255.255.255
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> controlplaneRouteModify after socket:44 with ip:118.99.107.65
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> controlplaneRouteModify socket:44 request:35084 dev:tsgw rtflags:0 with ip:118.99.107.65
    Feb 26 15:30:58  isakmpd[3542]: <103060> <3542> <DBUG> |ike|  118.99.107.65:2563-> ipc.c:controlplaneRouteModify:7524 Failed to Delete Route in Kernel: error:No such process
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> controlplaneRouteModify after ioctl sock:44 with ip:118.99.107.65
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> controlplaneRouteModify after close sock:44 with ip:118.99.107.65
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> delete_cp_route finished with ip:118.99.107.65
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> OutInfo notify-cookie
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563->   <-- R   Notify: COOKIE#SEND 60 bytes to 118.99.107.65(2563) (3745283.427)
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE_SAMPLE_ikeXchgSend: server instance 0
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> cleanup_and_free_context delete ctx memory
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> udp_encap_handle_message IKEv2 pkt status:0
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> udp_encap_handle_message ver:2 serverInst:0 pktsize:472
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE_EXAMPLE_IKE_msgRecv: ip:118.99.107.65  port:2563  server:0   len:472  numSkts:24
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> #RECV 472 bytes from 118.99.107.65(2563) at 10.232.12.11 (3745283.447)
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563->  spi={da4a525b68d8afe8 0000000000000000} np=N
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563->  exchange=IKE_SA_INIT msgid=0 len=468
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE_allocSa sa:0x1b4f7a4 peer:118.99.107.65:2563 id:1935128400 timestart:-549683849
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE2_xchgIn:1387
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE2_newXchg oExchange:34 bReq:0 dwMsgId:0
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> InNotify notify-cookie
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> InTfm entered  isakmp:0x77ec14
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE_cipherSuite: TfmId:12  policy-enc:12 keylen:16 policy-keylen:32
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563->   --> R   Notify: COOKIE (IKE)    Proposal #1: IKE(9)     ENCR_AES 128-BITS unsupported     ENCR_
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE_cipherSuite: TfmId:12  policy-enc:12 keylen:24 policy-keylen:32
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE_cipherSuite: TfmId:12  policy-enc:12 keylen:32 policy-keylen:32
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> AES 192-BITS unsupported     ENCR_AES 256-BITS     PRF_HMAC_SHA1     PRF_HMAC_MD5 skipped     PRF_
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE_macSuite: TfmId:2  policy:10004 mac:2
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE_checkGroup good dh:2  policy:2
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> InTfm Using Policy 10004, setting IKE_SA lifetime to 28800 seconds
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> InTfm: status=0 merror:0
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> InSa: after ACCEPT status:0 bMatch:1
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> InSa: after ACCEPT CHILD_SA  before BREAK status:0 bMatch:1
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> InKe initiator:NO
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> InKe responder: grp:ike 2
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> DH_allocateServer: postponing further processing until DH H/w completes
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> HMAC_SHA2_256 skipped     PRF_HMAC_SHA2_384 skipped     AUTH_HMAC_SHA1_96     DH_2   Notify:
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> NAT_DETECTION_SOURCE_IP   NAT_D (peer/NAT): 1c 8a 5e c1 99 af 00 b1 12 db eb 04 58 ab 36 db 69 ea
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> 2f d9
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563->    Notify: NAT_DETECTION_DESTINATION_IP   NAT_D (us/NAT): 89 be 22 3b a0 37 cc 13 d3 0e e7 a1 47 9d
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563->  43 61 1e 04 a5 b5
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> InVid
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563->    VID: 88 f0 e3 14 9b 3f a4 8b 05 aa 7f 68 5f 0b 76 6b e1 86 cc b8
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> Aruba VIA detected
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563->    VID: 40 48 b7 d5 6e bc e8 85 25 e7 de 7f 00 d6 c2 d3
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> Aruba Fragmentation request is received
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> Enabling Fragmentation for this SA
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563->    VID: ac 4a 8e 30 60 4a 34 c8 d5 82 78 8c dd a7 82 d5 cd 80 10 01
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> Aruba VIA UDID detected
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563->    VID: 56 49 41 20 41 75 74 68 20 50 72 6f 66 69 6c 65 20 3a 20 56 49 41 2d 74 65 73 74 2d 61 75
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> 74 68
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> check_aruba_vid: VIA Auth Profile : VIA-test-auth
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE2_msgRecv_resume dh1 pending, skipping outstanding send
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> group_get entered id:2
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> group_get ike_group:0x5c9728
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> modp_init entered
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> group_get group:0xcf3774
    Feb 26 15:30:58  isakmpd[3542]: <103060> <3542> <DBUG> |ike|  118.99.107.65:2563-> xlp_lib.c:xlp_send_dh_request_x_ikev2:311 rsa param allocated successfully
    Feb 26 15:30:58  isakmpd[3542]: <103060> <3542> <DBUG> |ike|  118.99.107.65:2563-> xlp_lib.c:xlp_send_dh_request_x_ikev2:318 rsa result allocated successfully
    Feb 26 15:30:58  isakmpd[3542]: <103060> <3542> <DBUG> |ike|  118.99.107.65:2563-> xlp_lib.c:xlp_send_dh_request_x_ikev2:327 rsa arg allocated successfully
    Feb 26 15:30:58  isakmpd[3542]: <103060> <3542> <DBUG> |ike|  118.99.107.65:2563-> xlp_lib.c:xlp_send_dh_request_x_ikev2:372 plen = 24
    Feb 26 15:30:58  isakmpd[3542]: <103060> <3542> <DBUG> |ike|  118.99.107.65:2563-> xlp_lib.c:xlp_send_dh_request_x_ikev2:431 nlm_crypto_do_op returned success, success code = 0
    Feb 26 15:30:58  isakmpd[3542]: <103060> <3542> <DBUG> |ike|  118.99.107.65:2563-> xlp_lib.c:xlp_send_dh_request_x_ikev2:441 DH1 request: peer: 118.99.107.65 dhflags:1 sos_pending:1
    Feb 26 15:30:58  isakmpd[3542]: <103060> <3542> <DBUG> |ike|   xlp_lib.c:xlp_rcv_response:691 Peer:118.99.107.65 obtained result frm param struct correctly from SAE response.
    Feb 26 15:30:58  isakmpd[3542]: <103060> <3542> <DBUG> |ike|   xlp_lib.c:process_xlp_dh1_response_ikev2:509 DH1 response: peer 118.99.107.65  sos_pending 0 grouplen 128
    Feb 26 15:30:58  isakmpd[3542]: <103060> <3542> <DBUG> |ike|   xlp_lib.c:xlp_send_dh_request_x_ikev2:444 DH2 request: peer: 118.99.107.65 dhflags:4 sos_pending:1
    Feb 26 15:30:58  isakmpd[3542]: <103060> <3542> <DBUG> |ike|   xlp_lib.c:process_xlp_dh2_response_ikev2:569 DH2 response: peer 118.99.107.65  sos_pending 0
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|   #SEND 345 bytes to 118.99.107.65(2563) (3745283.455)
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> udp_encap_handle_message ver:2 serverInst:0 pktsize:368
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE_EXAMPLE_IKE_msgRecv: ip:118.99.107.65  port:2563  server:0   len:368  numSkts:24
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> #RECV 368 bytes from 118.99.107.65(2563) at 10.232.12.11 (3745283.485)
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563->  spi={da4a525b68d8afe8 1eb41896293189f1} np=E{IDi}
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563->  exchange=IKE_AUTH msgid=1 len=364
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE2_newXchg oExchange:35 bReq:0 dwMsgId:1
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE2_newXchg before delXchg
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE2_delXchg Deleting exchange
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> authR_in
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> InSa0: calling IKE2_newIPsecSa
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563->   --> R   Notify: INITIAL_CONTACT   VID: 88 f0 e3 14 9b 3f a4 8b 05 aa 7f 68 5f 0b 76 6b e1 86 cc
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> b8
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> InCp
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563->    CFG_REQUEST
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> CheckCfgAttr type:1
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> CheckCfgAttr type:2
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> CheckCfgAttr type:3
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> CheckCfgAttr type:4
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> CheckCfgAttr type:5
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> InCp : detected VPN client
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> InTs entered
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> InTs  # of TS:1
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> InTs no:0 IPV4 addr:0.0.0.0  end:255.255.255.255
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563->     IP4_ADDRESS    IP4_NETMASK    IP4_DNS    IP4_NBNS    ADDR_EXP   TSi: 0.0.0.0~255.255.255.255
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> InTs responder:  the remote switch ip is :: pxIPsecSa->dwIP 0.0.0.0 pxIPsecSa->dwIPEnd 255.255.255.255
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> InTs no:1 IPV4 addr:0.0.0.0  end:255.255.255.255
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563->    TSr: 0.0.0.0~255.255.255.255
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563->    Notify: MOBIKE_SUPPORTEDEAP_authStateTransition: Transition Session 1:NULL from State NoState
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563->  to AuthDisabled
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> EAP_sessionCreate: Created EAP Session = 1
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> EAP_sessionRestart: Restart EAP, sessionId = 1
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> EAP_sessionRestart: Full restart EAP, sessionId = 1
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> EAP_passthruProcessULTransmit: Session 1:NULL Transmit Code 1, Type 1 Method State
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> EAP_METHOD_STATE_CONTINUE
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> EAP_authStateTransition: Transition Session 1:NULL from State AuthDisabled to AuthSendRequest
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> EAP_authStateTransition: Transition Session 1:NULL from State AuthSendRequest to AuthIdle
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> DoSa2_R : detected VPN client
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> authR_out
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE_useCert certchain:(nil)
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE_CUSTOM_useCert group ca-cert: bits: rsa:0 ec:0
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE_CUSTOM_useCert: found valid Server-Cert:idjktpsy06wlc01
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE_CUSTOM_useCert: got 1 certs
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> UseCustomCert: certNum:1
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE_certSetChain num:1
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE_certSetChain index:0 cert-len:1690 cert:0xb6f1e4 key:0xdab8dc keylen:2017
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> IKE_certSetChain status:0
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> OutId: status:0 authmtd:0
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563->   <-- R   HASH_r 3e 2a 6d 06 f0 ef 68 24 df 1e 28 b0 ec 83 d4 ad d2 33 8a 7b a1 6e 77 4b 02 78 c6
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> 2f ac a8 fa a5
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> #SEND 2144 bytes to 118.99.107.65(2563) (3745283.587)
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> Sending  no:1 fragment out of 3 fragments, size = 900
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> Sending  no:2 fragment out of 3 fragments, size = 900
    Feb 26 15:30:58  isakmpd[3542]: <103063> <3542> <DBUG> |ike|  118.99.107.65:2563-> Sending last fragment, size = 432
    Feb 26 15:31:39  isakmpd[3542]: <103063> <3542> <DBUG> |ike|   IKE2_delSa sa:0x1b4f7a4 peer:118.99.107.65:2563 id:4082612048 err:-90036 saflags:a00051 arflags:1
    Feb 26 15:31:39  isakmpd[3542]: <103063> <3542> <DBUG> |ike|   IKE2_delSa: deleting IPSEC SA 118.99.107.65:2563 due to deletion of un-rekeyed IKE_SA
    Feb 26 15:31:39  isakmpd[3542]: <103102> <3542> <INFO> |ike|  IKE SA deleted for peer 118.99.107.65
    Ananda Perdana
