MacSec Configuration
This thread has been viewed 31 times
  • 1.  MacSec Configuration
    Posted Apr 03, 2020 10:14 PM
    I have 3 switches. I am trying to set up a link from switch A to B and from switch C to B.
    The link between switch A and B is a VlAN with a /30 ip. I have one port on A and one on B that are untagged on that VLAN and I have RIP and MacSec running. This link works perfect.
    I tried the same with the link between switch B and C, but on switch B, MacSec keeps blocking the port and I dont know why.
    Switch A configs:
    macsec policy policyx
    Mode pre-shared-key ckn xxxxxxxx## cak ##xxxxxxxx
    macsec apply policy policyx c20
    aaa port-access mka server-priority 18 transmit-interval 4 c20
    vlan 1
    untagged c20
    ip address x.x.x.1 /30
    ip rip x.x.x.1
    switch B configs
    mode pre-shared-key ckn xxxxxxxx## cak ##xxxxxxxx
    vlan 1
    untagged c20
    ip address x.x.x.2 /30
    ip rip x.x.x.2
    That setup between A and B is good. I have the same between B and C just different ip, vlan # macsec policy and ckn/ cak...
  • 2.  RE: MacSec Configuration
    MVP
    Posted Sep 08, 2020 03:22 PM
    Did you ever resolve this?
    We're having a similar issue - 2930m <L2 P2P link> 5406v3
    Link works fine without macsec but the moment I try to enable macsec on it it goes down and doesn't come up again.
  • 3.  RE: MacSec Configuration
    MVP
    Posted Sep 14, 2020 07:47 PM
    Minor update - it seems that in our case the problem lay in the ISP/Infrastrucuture provider network.
    Also macsec was not entirely what we were looking for so the search continues....
