I have two Core switches : 10508 Chassis, I can see the MAD BFD is enabled on them, but when I use the command display bfd session it shows as down, and I need your help to check if the configuration is correct or there is something missing.
Please check output below, knowing that MAD vlan is vlan 1000.
[FMC-Core]dis mad verCurrent MAD status: DetectExcluded ports(configurable):Excluded ports(can not be configured):Ten-GigabitEthernet1/0/0/15Ten-GigabitEthernet1/0/0/16Ten-GigabitEthernet2/0/0/15Ten-GigabitEthernet2/0/0/16MAD LACP disabled.MAD BFD enabled interface:Vlan-interface1000mad ip address 10.10.10.1 255.255.255.252 member 1mad ip address 10.10.10.2 255.255.255.252 member 2==================================================
[FMC-Core]dis bfd session Total session number: 1 Up session number: 0 Init mode: ActiveIPv4 session working under Ctrl mode:LD/RD SourceAddr DestAddr State Holdtime Interface513/0 10.10.10.1 10.10.10.2 Down / Vlan1000
interface GigabitEthernet1/3/0/44
port link-mode bridge
description MAD
port access vlan 1000
stp disable
return
[FMC-Core-GigabitEthernet1/3/0/44]inter g2/3/0/44
[FMC-Core-GigabitEthernet2/3/0/44]dis this
interface GigabitEthernet2/3/0/44
description MAD
stp disable
