Remote Access
last person joined: 8 days ago
magic vlan
This thread has been viewed 60 times
  • 1.  magic vlan
    Posted Jan 10, 2021 01:02 PM
    Hi
    I found it is assign ip to wireless client in the Instant,that is the Factory configuration.
    Is it only this way?
    By the way , can i modify or  delete  it.
    sorry,english not good
  • 2.  RE: magic vlan
    MVP EXPERT
    Posted Jan 11, 2021 04:28 AM
    To stop using the 'magic vlan' within the IAP​ and your clients​, you should select Network Assigned under Client IP assignment within your SSID profile.
    https://www.arubanetworks.com/techdocs/Instant_86_WebHelp/Content/instant-ug/wlan-ssid-conf/conf-vlan-sett.htm
    If you wish to use a different IP range and the IAP act as a DHCP Server, use the following:
    https://www.arubanetworks.com/techdocs/Instant_86_WebHelp/Content/instant-ug/dhcp-conf/def-dhcp-sco.htm?Highlight=dhcp
    Craig Syme
  • 3.  RE: magic vlan
    Posted Jan 11, 2021 06:19 AM
    The magic VLAN is use when you do 'VC assigned addresses' and it is used mostly for guest users. The guest user's traffic will be source-natted on the VC, so you will never see that IP range on the network.
    The selection of the IP range is somewhat smart, as if you have a 10.x.x.x IP for the AP it will take another private IP range, like 172.16.x.x or 192.168.x.x; similar with one of the other private ranges.
    If you need full control, create your own VLAN and assign IP, DHCP, etc.
