Mailgun integration into CPPM
  • 1.  Mailgun integration into CPPM
    Posted May 29, 2017 09:39 PM
    I was wondering if someone made integration into Clearpass.
    I tried to add server into:
    Administration » External Servers » Endpoint Context Servers
    Then:
    Administration » Dictionaries » Context Server Actions
    I created generic HTTP context server but I have no idea what to put exactly into HEADERS, CONTENT, ATTRIBUTES
    After I used my info example from below works fine in my OS terminal
    curl -s --user 'api:MY_KEY' \
        https://api.mailgun.net/v3/sandboxaMY_NUMBER.mailgun.org/messages \
        -F from='Excited User <mailgun@sandboxaMY_NUMBER.mailgun.org>' \
        -F to='test@test.com' \
        -F subject='Hello' \
        -F text='Testing some Mailgun awesomness!'
    Here is Mailgun API info  https://documentation.mailgun.com/api-intro.html#introduction
    Here I found old way of integrating similar service from SendGrid but their API has changed
    https://community.arubanetworks.com/t5/ClearPass-Recipes/SendGrid-Email-Notification/ta-p/204343
  • 2.  RE: Mailgun integration into CPPM
    Posted Jun 01, 2017 10:19 PM
    Username should be: api
    Password: < your-api-key >
    In the Endpoint Context Server Actions config:
    Action
    URL:
    /messages
    Header:
    Content-Type     application/x-www-form-urlencoded
    Content:
    Notice that the contents are URL encoded with the exception of dynamic ClearPass variables (those will be encoded after they are replaced).
    from=Aruba+Boston+%3Cno-reply%40arubaboston.com%3E&to=%{Endpoint:Email}&subject=Device+Quarantined&text=Your+device+has+been+blocked+from+the+network+due+to+abuse.+Please+contact+the+help+desk%2E
    Here is a good URL encoding tool: https://www.freeformatter.com/url-encoder.html
  • 3.  RE: Mailgun integration into CPPM
    Posted Jun 01, 2017 10:43 PM
    Sth is still not working
    What could be wrong?
  • 4.  RE: Mailgun integration into CPPM
    Posted Jun 01, 2017 11:04 PM
    Ok found it
    BASE URL should be: https://api.mailgun.net/v3
    URL in the ACTION should be: /YOUR_FULL_DOMAIN/messages
  • 5.  RE: Mailgun integration into CPPM
    Posted Jun 01, 2017 11:20 PM
    Yeah, either way. /domain/ can go in base URL or action. Doesn’t matter.
