Yeah i backed everything up just in case and also i asked for a maintenance window but everything just went fine
Original Message:
Sent: Apr 25, 2024 12:40 PM
Subject: Managed switches on aruba central importing question
Hello!
When you first connect a switch to central, you can move the switch to the UI Group and with ONLY* CXs you can select "retain configuration"
This will keep the current configuration, however to be safe I'd recommend backing up the configuration. lol.
With AOS-S, it will over-write the current configuration.
Original Message:
Sent: Apr 24, 2024 01:26 PM
Hello i would like to know if you already have a group with this settings
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/2c33b0b4b1d34e4aa768f6bf2728f51a.png)
Let say the group is called Aruba-CX-Switches
i already have 5 switches in there and i need to move 2 more switches that were not in central, but already have config with the retain config feature?
Will it retain the config and it will not affect the other 5 switches config that i already have in the Aruba-CX-Switches group?
