Management Authentication using Windows NPS
This thread has been viewed 16 times
  • 1.  Management Authentication using Windows NPS
    Posted Dec 31, 2015 01:06 PM
    I have also opened a case with Aruba TAC, but wanted to post on the board as well.
    Is there updated information for Authentication using Windows NPS?
    The only instructions I can locate is with IAS, which was replaced by NPS, and the steps are outdated and not clear. The document I am referring to is attached.
    Note: The goal, at this time, only for allowing specific staff members to login to the Aruba controller for management purposes with their domain credentials.
  • 2.  RE: Management Authentication using Windows NPS
    Posted Dec 31, 2015 01:24 PM
    You need to use RADIUS to accomplish this.
    In NPS you need to create a policy using PAP as the authentication method.
    - First create AAA Profile using your current RADIUS server group pointed to the NPS server within the AAA Profile add a NAS-ID of your choice
    - Create a Policy in NPS with the NAS-ID you used in the previous step and also add the AD group you would like to allowed , the authentication type needs to be PAP (Unsecured). This rule should be move to the top.
    - Finally in the Controller point the management to the new AAA profile with local fallback
    Pardon typos sent from Mobile
  • 3.  RE: Management Authentication using Windows NPS
    Posted Jan 17, 2020 09:12 AM
    Good day,
    I appreciate  i am replying to an oooold post but is the authentcation 'PAP' still the only method for this process.
    Ta
    Manny
