Cloud Managed Networks
Management of Instant APs after adding to Aruba Central
  • 1.  Management of Instant APs after adding to Aruba Central
    Posted Sep 15, 2016 10:09 PM
    We are testing some IAP-205's with both local and cloud mangement.
    After adding the IAP's to Aruba Central, we discovered we cannot manage them locally anymore via instant.arubanetworks.com:4343.
    Mangement is only via one or the other and not both?
    pablo
  • 2.  RE: Management of Instant APs after adding to Aruba Central
    Posted Sep 15, 2016 10:20 PM
    Yes, that's correct. Only basic functions are available when the device is being managed.
  • 3.  RE: Management of Instant APs after adding to Aruba Central
    Posted Sep 15, 2017 08:18 PM
    Hi guys,
    Another question, which credencials are used to login locally to the IAP? Once I added the APs in the Central portal I noticed that I no longer could access with default credentials "admin" "admin".
  • 4.  RE: Management of Instant APs after adding to Aruba Central
    Posted Feb 08, 2018 01:22 PM
    I found in the system screen under wireless management app there is an administrator user and password. You can use it to changue the local admin password but it only works temporaly, soon the credentials are changed again by aruba central.
  • 5.  RE: Management of Instant APs after adding to Aruba Central
    Posted Feb 08, 2018 09:18 PM
    Hi Adolfo,
    The IAP's will be part of a group on Central.
    When you create a group, it will ask you for setting up a group password. Once the IAP is moved to this group, the group password is used as login credentials for the IAP.
    In case you need to change them, use the following steps:
    1. Navigate to the group.
    2. Select wireless management.
    3. Click on System
    4. Administration.
    I have attached the screenshot for reference.
    In my case IAP is on a group named TAC.
  • 6.  RE: Management of Instant APs after adding to Aruba Central
    Posted Feb 09, 2018 02:34 PM
    great, it is work as intended, but if you want to change only for a VC  and no other VC in the same group?
  • 7.  RE: Management of Instant APs after adding to Aruba Central
    Posted Feb 11, 2018 01:43 AM
    Aruba Central allows overriding any part of the configuration on a per-device (in this case, per-VC) basis. Simply go to the filter on the top and select your device.
