Management user authentication through RADIUS
This thread has been viewed 48 times
  • 1.  Management user authentication through RADIUS
    Posted Aug 08, 2014 11:11 AM
    Hi Airheads Communtiry,
    I am currently facing an issue at the controller of a customer of mine.
    Regarding to this old discussion I tried to troubleshoot the configuration or the behavior.
    But I was Unable to resolve the issue.
    I try to authenticate admin users and Lobby Users via Radius.
    But I am currently even unable to simply authenticate into the default role and I am not sure where the misconfiguration is.
    Do I have to change the configuration of my Controller or is there a problem at the configuration of my Radius?
    I can provide you the output of the Debug I have performed already like it was described in the old discussion.
    Aug 8 15:13:37 :124011:  <INFO> |authmgr|  Test authenticating user winketa:****** using server Radius1
    Aug 8 15:13:37 :121041:  <DBUG> |authmgr|  User winketa MAC=00:00:00:00:00:00 not found.
    Aug 8 15:13:37 :124004:  <DBUG> |authmgr|  Auth server 'Radius1' response=0
    Aug 8 15:13:37 :124019:  <INFO> |authmgr|  Test server response: Authentication Successful
    Aug 8 15:11:38 :124004:  <DBUG> |authmgr|  RX (sock) message of type 1, len 1016
    Aug 8 15:11:38 :124546:  <DBUG> |authmgr|  aal_authenticate user:winketa vpnflags:0.
    Aug 8 15:11:38 :124004:  <DBUG> |authmgr|  unknown user=172.31.29.241, method=Management
    Aug 8 15:11:38 :124547:  <DBUG> |authmgr|  aal_authenticate server_group:default.
    Aug 8 15:11:38 :124004:  <DBUG> |authmgr|  Select server for method=Management, user=winketa, essid=<>, server-group=KVB_RADIUS_ADMIN, last_srv <>
    Aug 8 15:11:38 :124004:  <DBUG> |authmgr|   server=Radius1, ena=1, ins=1 (1)
    Aug 8 15:11:38 :124038:  <INFO> |authmgr|  Selected server Radius1 for method=Management; user=winketa,  essid=<>, domain=<>, server-group=RADIUS_ADMIN
    Aug 8 15:11:38 :124064:  <NOTI> |authmgr|  Administrative User result=Authentication failed(1), method=Management, username=winketa IP=172.31.29.241 auth server=Radius1
    Aug 8 15:11:38 :124003:  <INFO> |authmgr|  Authentication result=Authentication failed(1), method=Management, server=Radius1, user=172.31.29.241
    Aug 8 15:11:38 :124004:  <DBUG> |authmgr|  Auth server 'Radius1' response=1
    Aug 8 15:11:38 :125022:  <WARN> |aaa|  Authentication failed for User winketa, Logged in from 172.31.29.241 port 56934, Connecting to 172.31.190.50 port 4343 connection type HTTPS
    I tried to login via with the User "winketa" in the AAA diagnostics tool everything went fine. As you see in my first authentication attempt. The radius returns a successful authentication.
    But if I try to log into the WebGUI using the same credentials the controller sends some additional information to the radius like the issuing hosts IP address.
    I think this is why my radius sends a authentication reject.
    But I cant see where I can change this behavior.
    Or where my misconfiguration is?
    Here I have a screenshot with my current configuration.
    I already tried several "Server Rules" I also tried to have no "Server Rules" applied but nothing changed the current behavior.
    Do you guys have any idea how to solve this issue?
    I like to thank you for your support in advance!
    Greetings
    WiFi_Newbie
  • 2.  RE: Management user authentication through RADIUS
    Posted Aug 08, 2014 11:18 AM
    If I remember right, AAA test server uses PAP by default and the real mgmt authentication uses CHAP. Do you have CHAP enabled on the RADIUS server rule/service that the mgmt requests are hitting?
  • 3.  RE: Management user authentication through RADIUS
    Posted Aug 08, 2014 11:55 AM
    Oh I see that the link to the old discussion doesnt work as Hyperlink so I will add it here as plain text just for completeness maybe there is something interesting in it for you guys.
    http://community.arubanetworks.com/t5/ArubaOS-and-Controllers/Management-user-authentication-through-RADIUS/td-p/2928
    Thanks olino for the quick response.
    I retried the test an I saw that on the diagnostics page it says that it is using MSCHAPv2 but you are able to use PAP also.
    I tried both mechanisms.
    MSCHAPv2
    PAP
    Here are the output of the AAA Logging during the test.
    MSCHAPv2
    Aug 8 16:29:21 :124011:  <INFO> |authmgr|  Test authenticating user winketa:****** using server Radius1
    Aug 8 16:29:21 :121041:  <DBUG> |authmgr|  User winketa MAC=00:00:00:00:00:00 not found.
    Aug 8 16:29:21 :124004:  <DBUG> |authmgr|  Auth server 'Radius1' response=0
    Aug 8 16:29:21 :124019:  <INFO> |authmgr|  Test server response: Authentication Successful
    PAP
    Aug 8 16:29:57 :124011:  <INFO> |authmgr|  Test authenticating user winketa:****** using server Radius1
    Aug 8 16:29:57 :124004:  <DBUG> |authmgr|  Auth server 'Radius1' response=1
    Aug 8 16:29:57 :124019:  <INFO> |authmgr|  Test server response: Authentication failed
    Looks like it is about the response "0" means allowed and "1" means rejected.
    But if I try to logon regular into the GUI I am unable to perform a simple MSCHAPv2 request only with the given credentials.
    The Controller always send some stuff like the issuing hosts IP Address and so on.
    Maybe someone has any clue?
    Greetings
    WiFi_Newbie
  • 4.  RE: Management user authentication through RADIUS
    Posted Aug 08, 2014 12:24 PM
    What do the logs of the radius server say? The radius server configuration is the other side of the answer.
  • 5.  RE: Management user authentication through RADIUS
    Posted Mar 22, 2024 10:32 AM
    Nearly 10 years later I am having the same issue.  I've set up AAA on the Aruba WLC, successfully run the AAA Server Test tool against my management user, but can login to neither the GUI nor CLI.  I don't see a resolution to the OP's problem.  I'm using the same RADIUS server for SSH switch management and Cisco Prime Infrastructure management.  Why would the Aruba diagnostic tool report that it can authenticate against RADIUS, the RADIUS logs tell me that the user account is granted access, but the get denied by the CLI and GUI?  TIA!
  • 6.  RE: Management user authentication through RADIUS
    Posted Mar 27, 2024 03:17 AM
    Admin login on the Aruba controller works fine, what error message do you get in ClearPass?
    Please also share the admin authentication options for the controller.
    Waldemar
    ACCX # 1377, ACEP, ACX - Network Security
  • 7.  RE: Management user authentication through RADIUS
    Posted 30 days ago
    I'll give you the TL;DR version of the story.
    ClearPass is not currently online. Yes, the local admin account works fine. NPS says access granted. The controller error reads:
    aaa[3628]:<125022> <3628> <WARN> |aaa| Authentication failed for "user", Logged in from x.x.x.x port 22, Connecting to y.y.y.y  port 55115 connection type SSH
    and another error message follows which reads: Failed password for "user" from x.x.x.x port 55115 ssh2.
    Admin Authentication Options
    default role: standard
    enable: checked
    mschapv2: unchecked
    server group: "the one I created"
    management telnet access: unchecked
    Login activities persistence period: 0 days
    Login banner text: NA
    Banner has to be accepted: unchecked
    I appreciate your input!
  • 8.  RE: Management user authentication through RADIUS
    Posted 30 days ago
    The config looks the same for me.
    Does NPS send any aruba-radius-attributes or just an accept?
    Increase the log level for security-aaa and security-auth-amon to debugging and check logs again.
    Waldemar
  • 9.  RE: Management user authentication through RADIUS
    Posted 30 days ago
    This is what my logs look like after increasing the log level as suggested:
    authmgr [3715]: <121031> <3715> <DBUG> |authmgr| |aaa| [tc_api.c:444] Radius authenticate user (username) PAP using server SERVERNAME
    authmgr [3715]: <121031> <3715> <DBUG> |authmgr| |aaa| [tc_request.c:91] Add request: id=39, server=SERVERNAME, IP=x.x.x.x, server-group=SERVERGROUP, fd=72
    authmgr [3715]: <121031> <3715> <DBUG> |authmgr| |aaa| [tc_server.c:2618] Sending radius request to SERVERNAME:x.x.x.x id:39,len=136
    authmgr [3715]: <121031> <3715> <DBUG> |authmgr| |aaa| [tc_request.c:123] Find request: id=39, svr=x.x.x.x, fd=72
    authmgr [3715]: <121031> <3715> <DBUG> |authmgr| |aaa| [tc_request.c:134] Current entry: server=SERVERNAME IP=x.x.x.x, server-group=SERVERGROUP, fd=72
    authmgr [3715]: <121031> <3715> <DBUG> |authmgr| |aaa| [tc_request.c:63] Del request: id=39, server=SERVERNAME, IP=x.x.x.x, server-group-SERVERGROUP fd=72
  • 10.  RE: Management user authentication through RADIUS
    Posted 25 days ago
    You can record the admin login with packet-capture:
    Check if packet-capture is already active: show packet-capture.
    Start packet-capture :packet-capture controlpath udp 1812,1813
    Perform a test login.
    Show the result: show packet-capture controlpath-pcap.
    If required, you can save the packet capture in a file, download it and open it with wireshark: packet-capture copy-to-flash controlpath-pcap. The controller uses the file name controlpath-pcap.tar.gz.
    Terminate packet-capture with: no packet-capture controlpath udp 1812,1813.
    Clean up packet-capture: packet-capture reset-pcap controlpath-pcap.
    If "Access Accept" is displayed in packet capture, but the user cannot log in - open a case.
    Waldemar
